Singular Trajectories and the Contrast Imaging Problem in Nuclear Magnetic Resonance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2013
In this article, the contrast imaging problem in nuclear magnetic resonance is modeled as a Mayer problem in optimal control whose solutions can be parameterized using Pontryagin's maximum principle and analyzed using geometric optimal control. In particular, the optimal problem can be mainly reduced to the analysis of the Hamiltonian dynamics describing the singular trajectories, and encoding their optimality status.
Fichier non déposé
hal-00939496 , version 1 (30-01-2014)
Bernard Bonnard, Monique Chyba, John Marriott. Singular Trajectories and the Contrast Imaging Problem in Nuclear Magnetic Resonance. SIAM Journal on Control and Optimization, 2013, 51 (2), pp.1325-1349. ⟨10.1137/110833427⟩. ⟨hal-00939496⟩
166 Consultations
0 Téléchargements
