Bilateral control of teleoperators with time delay, IEEE Transactions on Automatic Control, vol.34, issue.5, pp.494-501, 1989. ,
DOI : 10.1109/9.24201
Control schemes for teleoperation with time delay: A comparative study, Robotics and Autonomous Systems, vol.38, issue.1, pp.49-64, 2002. ,
DOI : 10.1016/S0921-8890(01)00164-6
Bilateral Teleoperation Over Unreliable Communication Networks, IEEE Transactions on Control Systems Technology, vol.16, issue.2, pp.304-313, 2008. ,
DOI : 10.1109/TCST.2007.903397
On tracking performance in bilateral teleoperation, IEEE Transactions on Robotics, vol.22, issue.4, pp.861-866, 2006. ,
DOI : 10.1109/TRO.2006.878942
Time-delayed bilateral teleoperation with force estimation for n-DOF nonlinear robot manipulators, 2010 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.3911-3918, 2010. ,
DOI : 10.1109/IROS.2010.5649183
Stability of Teleoperation Systems for Time-Varying REFERENCES 15, 2009. ,
A new Lyapunov technique for robust control of systems with uncertain non-small delays, IMA Journal of Mathematical Control and Information, vol.23, issue.2, pp.165-179, 2006. ,
DOI : 10.1093/imamci/dni051
New bounded real lemma representations for time-delay systems and their applications, IEEE Transactions on Automatic Control, vol.46, issue.12, pp.1973-1979, 2001. ,
DOI : 10.1109/9.975503
Observer-based Higher-Order Sliding Mode Impedance Control of Bilateral Teleoperation under Constant Unknown Time Delay, 2006 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.609-617, 2007. ,
DOI : 10.1109/IROS.2006.282126
Stability of Time-Delay Systems, 2003. ,
DOI : 10.1007/978-1-4612-0039-0
URL : https://hal.archives-ouvertes.fr/hal-00664367
Delay-range-dependent stability for systems with time-varying delay, Automatica, vol.43, issue.2, pp.371-376, 2007. ,
DOI : 10.1016/j.automatica.2006.08.015
Design on a Half Closed-Loop Bilateral Teleoperation System, Proc. Chinese Control Conference (CCC'10), pp.3432-3436, 2010. ,
Delay-Dependent Stability Criteria of Teleoperation Systems With Asymmetric Time-Varying Delays, IEEE Transactions on Robotics, vol.26, issue.5, pp.925-932, 2010. ,
DOI : 10.1109/TRO.2010.2053736
Teleoperation Over the Internet With/Without Velocity Signal, IEEE Transactions on Instrumentation and Measurement, vol.60, issue.1, pp.4-13, 2011. ,
DOI : 10.1109/TIM.2010.2065410
A gain scheduling strategy for the control and estimation of a remote robot via Internet, 2008 27th Chinese Control Conference, pp.793-799, 2008. ,
DOI : 10.1109/CHICC.2008.4605866
URL : https://hal.archives-ouvertes.fr/inria-00266451
A Switched System Approach to Exponential Stabilization Through Communication Network, IEEE Transactions on Control Systems Technology, vol.20, issue.4, 2011. ,
DOI : 10.1109/TCST.2011.2159793
URL : https://hal.archives-ouvertes.fr/inria-00602327
Time-Delay Compensation by Communication Disturbance Observer for Bilateral Teleoperation Under Time-Varying Delay, IEEE Transactions on Industrial Electronics, vol.57, issue.3, pp.1050-1062, 2010. ,
DOI : 10.1109/TIE.2009.2028337
Passivity-based control for bilateral teleoperation: A tutorial, Automatica, vol.47, issue.3, pp.485-495, 2011. ,
DOI : 10.1016/j.automatica.2011.01.004
Position Tracking for Non-linear Teleoperators with Variable Time Delay, The International Journal of Robotics Research, vol.24, issue.8, pp.895-910, 2009. ,
DOI : 10.1177/0278364908099461
Reciprocally convex approach to stability of systems with time-varying delays, Automatica, vol.47, issue.1, pp.235-238, 2011. ,
DOI : 10.1016/j.automatica.2010.10.014
A Force-Reflection Algorithm for Improved Transparency in Bilateral Teleoperation With Communication Delay, IEEE/ASME Transactions on Mechatronics, vol.12, issue.3, pp.361-374, 2007. ,
DOI : 10.1109/TMECH.2007.897285
Time-delay systems: an overview of some recent advances and open problems, Automatica, vol.39, issue.10, pp.1667-1694, 2003. ,
DOI : 10.1016/S0005-1098(03)00167-5
A control architecture for dual user teleoperation with unknown time delays: A sliding mode approach, 2010 IEEE/ASME International Conference on Advanced Intelligent Mechatronics, pp.1221-1226, 2010. ,
DOI : 10.1109/AIM.2010.5695910
New delay-dependent stability criteria for systems with interval delay, Automatica, vol.45, issue.3, pp.744-749, 2009. ,
DOI : 10.1016/j.automatica.2008.09.010
Neural network-based teleoperation using Smith predictors, IEEE International Conference Mechatronics and Automation, 2005, pp.1654-1659, 2005. ,
DOI : 10.1109/ICMA.2005.1626803
The standard H/sub ???/ problem in systems with a single input delay, IEEE Transactions on Automatic Control, vol.45, issue.3, pp.382-397, 2000. ,
DOI : 10.1109/9.847719
Remote Stabilization Via Communication Networks With a Distributed Control Law, IEEE Transactions on Automatic Control, vol.52, issue.8, pp.1480-1485, 2007. ,
DOI : 10.1109/TAC.2007.902757
URL : https://hal.archives-ouvertes.fr/hal-00201790
New results on delay-dependent robust <mml:math altimg="si24.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msub><mml:mrow><mml:mi>H</mml:mi></mml:mrow><mml:mrow><mml:mo>???</mml:mo></mml:mrow></mml:msub></mml:math> control for systems with time-varying delays, Automatica, vol.42, issue.2, pp.343-348, 2006. ,
DOI : 10.1016/j.automatica.2005.09.013
Time domain passivity control of teleoperation systems with random asymmetric time delays, Proceedings of the 48h IEEE Conference on Decision and Control (CDC) held jointly with 2009 28th Chinese Control Conference, pp.7533-7538, 2009. ,
DOI : 10.1109/CDC.2009.5399893
A Power-Based Time Domain Passivity Control for Haptic Interfaces, IEEE Transactions on Control Systems Technology, vol.19, issue.4, pp.874-883, 2011. ,
DOI : 10.1109/TCST.2010.2062513
Trends in Networked Control Systems, Proc. World Congress the International Federation of Automatic Control, pp.2886-2894, 2008. ,
DOI : 10.3182/20080706-5-KR-1001.00486
A novel control scheme for teleoperation with guaranteed performance under time-varying delays, 2011 Chinese Control and Decision Conference (CCDC), 2011. ,
DOI : 10.1109/CCDC.2011.5968191
URL : https://hal.archives-ouvertes.fr/hal-00602338
Robust <mml:math altimg="si11.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msub><mml:mrow><mml:mi>H</mml:mi></mml:mrow><mml:mrow><mml:mo>???</mml:mo></mml:mrow></mml:msub></mml:math> filtering for a class of uncertain linear systems with time-varying delay, Automatica, vol.44, issue.1, pp.157-166, 2008. ,
DOI : 10.1016/j.automatica.2007.04.024
