Detecting mental states of alertness with genetic algorithm variable selection - Archive ouverte HAL Access content directly
Conference Papers Year : 2013
Email Print Request Permissions Save to Project The objective of the present work is to develop a method able to automatically determine mental states of vigilance; i.e., a person's state of alertness. Such a task is relevant to diverse domains, where a person is expected or required to be in a particular state. For instance, pilots or medical staffs are expected to be in a highly alert state, and this method could help to detect possible problems. In this paper, an approach is developed to predict the state of alertness ("normal" or "relaxed") from the study of electroencephalographic signals (EEG) collected with a limited number of electrodes. The EEG of 58 participants in the two alertness states (116 records) were collected via a cap with 58 electrodes. After a data validation step, 19 subjects were retained for further analysis. A genetic algorithm was used to select an optimal subset of electrodes. Common spatial pattern (CSP) coupled to linear discriminant analysis (LDA) was used to build a decision rule and thus predict the alertness of the participants. Different subset sizes were investigated and the best result was obtained by considering 9 electrodes (correct classification rate of 73.68%).
Not file
Dates and versions
hal-00939851 , version 1 (30-01-2014)
Identifiers
  • HAL Id : hal-00939851 , version 1
Cite
Laurent Vezard, Pierrick Legrand, Marie Chavent, Frederique Faita-Ainseba, Leonardo Trujillo. Detecting mental states of alertness with genetic algorithm variable selection. IEEE Congress on Evolutionary Computation (CEC) 2013, Jun 2013, Cancun, Mexico. pp.1247 - 1254. ⟨hal-00939851⟩
167 View
0 Download
Share
