Probing for Loss: The Case Against Probe Trains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Letters Année : 2011
We assess the bias and variance of active probing measurement techniques for loss in networks. We show that loss probability is best measured using isolated probes rather than with probe 'trains', which contrasts with prior work which found that probe trains better estimate statistics of lossy periods.
Fichier non déposé
hal-00940542 , version 1 (01-02-2014)
  • HAL Id : hal-00940542 , version 1
François Baccelli, Sridhar Machiraju, Darryl Veitch, Jean Bolot. Probing for Loss: The Case Against Probe Trains. IEEE Communications Letters, 2011, 15 (5), pp.590-592. ⟨hal-00940542⟩
153 Consultations
0 Téléchargements
