Gravity inversion using wavelet-based compression on parallel hybrid CPU/GPU systems: application to southwest Ghana - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Journal International Année : 2013
We solve the 3-D gravity inverse problem using a massively parallel voxel (or finite element) implementation on a hybrid multi-CPU/multi-GPU (graphics processing units/GPUs) cluster. This allows us to obtain information on density distributions in heterogeneous media with an efficient computational time. In a new software package called TOMOFAST3D, the inversion is solved with an iterative least-square or a gradient technique, which minimizes a hybrid L1-/L2-norm–based misfit function. It is drastically accelerated using either Haar or fourth-order Daubechies wavelet compression operators, which are applied to the sensitivity matrix kernels involved in the misfit minimization. The compression process behaves like a pre-conditioning of the huge linear system to be solved and a reduction of two or three orders of magnitude of the computational time can be obtained for a given number of CPU processor cores. The memory storage required is also significantly reduced by a similar factor. Finally, we show how this CPU parallel inversion code can be accelerated further by a factor between 3.5 and 10 using GPU computing. Performance levels are given for an application to Ghana, and physical information obtained after 3-D inversion using a sensitivity matrix with around 5.37 trillion elements is discussed. Using compression the whole inversion process can last from a few minutes to less than an hour for a given number of processor cores instead of tens of hours for a similar number of processor cores when compression is not used.
ggt334.pdf (11.53 Mo) Télécharger le fichier
hal-00941851 , version 1 (18-06-2021)
Roland Martin, Vadim Monteiller, Dimitri Komatitsch, Stéphane Perrouty, Mark Jessell, et al.. Gravity inversion using wavelet-based compression on parallel hybrid CPU/GPU systems: application to southwest Ghana. Geophysical Journal International, 2013, 195 (3), pp.1594-1619. ⟨10.1093/gji/ggt334⟩. ⟨hal-00941851⟩
462 Consultations
21 Téléchargements
