Beyond "project and sign" for cosine estimation with binary codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Raghavendran Balu
Teddy Furon
Hervé Jégou
  • Fonction : Auteur
  • PersonId : 833473
Many nearest neighbor search algorithms rely on encoding real vectors into binary vectors. The most common strategy projects the vectors onto random directions and takes the sign to produce so-called sketches. This paper discusses the sub-optimality of this choice, and proposes a better encoding strategy based on the quantization and reconstruction points of view. Our second contribution is a novel asymmetric estimator for the cosine similarity. Similar to previous asymmetric schemes, the query is not quantized and the similarity is computed in the compressed domain. Both our contribution leads to improve the quality of nearest neighbor search with binary codes. Its efficiency compares favorably against a recent encoding technique.
icassp_beyond_project_sign.pdf (198.44 Ko) Télécharger le fichier
Format : Figure, Image
hal-00942075 , version 1 (04-02-2014)
  • HAL Id : hal-00942075 , version 1
Raghavendran Balu, Teddy Furon, Hervé Jégou. Beyond "project and sign" for cosine estimation with binary codes. ICASPP - International Conference on Acoustics, Speech, and Signal Processing, IEEE, May 2014, Florence, Italy. ⟨hal-00942075⟩
444 Consultations
511 Téléchargements
