Limits and dynamics of stochastic neuronal networks with random heterogeneous delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Physics Année : 2013
Realistic networks display heterogeneous transmission delays. We analyze here the limits of large stochastic multi-populations networks with stochastic coupling and random interconnection delays. We show that depending on the nature of the delays distributions, a quenched or averaged propagation of chaos takes place in these networks, and that the network equations converge towards a delayed McKean-Vlasov equation with distributed delays. Our approach is mostly fitted to neuroscience applications. We instantiate in particular a classical neuronal model, the Wilson and Cowan system, and show that the obtained limit equations have Gaussian solutions whose mean and standard deviation satisfy a closed set of coupled delay differential equations in which the distribution of delays and the noise levels appear as parameters. This allows to uncover precisely the effects of noise, delays and coupling on the dynamics of such heterogeneous networks, in particular their role in the emergence of synchronized oscillations. We show in several examples that not only the averaged delay, but also the dispersion, govern the dynamics of such networks.
hal-00942213 , version 1 (04-02-2014)
Jonathan Touboul. Limits and dynamics of stochastic neuronal networks with random heterogeneous delays. Journal of Statistical Physics, 2013, 149 (4), pp.569-597. ⟨10.1007/s10955-012-0607-6⟩. ⟨hal-00942213⟩
337 Consultations
0 Téléchargements
