On automatic stability of a ship on a given course, Proceedings of the Cenral Communication Laboratory, pp.34-75, 1934. ,
Sliding Modes in Control Optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
ContributionàContribution`Contributionà l'´ etude mathématique des systèmes de réglage par tout ou rien, 1949. ,
Theory of control relay systems, Moscow: Gostekhizdat, 1955. ,
On pecularities of variable structure control systems with discontinuous switching functions, Doklady AN USSR, vol.153, pp.776-778, 1963. ,
Sliding mode control for gradient tracking and robot navigation using artificial potential fields, IEEE Transactions on Robotics and Automation, vol.11, issue.2, pp.247-254, 1995. ,
DOI : 10.1109/70.370505
Multivariable variable-structure adaptive model-following control systems, IEE Proceedings D Control Theory and Applications, vol.129, issue.1, p.6, 1982. ,
DOI : 10.1049/ip-d.1982.0002
Sliding mode observers. Tutorial, Proceedings of 1995 34th IEEE Conference on Decision and Control, pp.3376-3378, 1995. ,
DOI : 10.1109/CDC.1995.479009
The invariance conditions in variable structure systems, Automatica, vol.5, issue.3, pp.287-295, 1969. ,
DOI : 10.1016/0005-1098(69)90071-5
Sliding regimes in general non-linear systems: a relative degree approach, International Journal of Control, vol.3, issue.4, pp.1487-1506, 1989. ,
Variable structure control of nonlinear multivariable systems: a tutorial, Proceedings of the IEEE, pp.212-232, 1988. ,
DOI : 10.1109/5.4400
Sliding mode control: theory and applications, 1998. ,
Sliding Mode Control in Engineering, 2002. ,
DOI : 10.1201/9780203910856
Sliding order and sliding accuracy in sliding mode control, International Journal of Control, vol.51, issue.6, pp.1247-1263, 1993. ,
DOI : 10.1109/TAC.1977.1101661
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
Theory and Application of Liapunov's Direct Method, E. Cliffs, 1963. ,
Finite Time Controllers, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
DOI : 10.1137/0324047
Stability of Motion, 1967. ,
DOI : 10.1007/978-3-642-50085-5
Lyapunov analysis of finite-time differential equations, Proceedings of 1995 American Control Conference, ACC'95, pp.1831-1832, 1995. ,
DOI : 10.1109/ACC.1995.531201
Finite time stability of non linear systems, IEEE Conference on Decision and Control, pp.3641-3646, 2003. ,
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Finite time stability conditions for non-autonomous continuous systems, International Journal of Control, vol.55, issue.5, pp.797-803, 2008. ,
DOI : 10.1080/00207177908922792
URL : https://hal.archives-ouvertes.fr/hal-00177572
Global Finite-time Observers for a Class of Non-Lipschitz Systems, IFAC Proceedings Volumes, vol.44, issue.1, pp.703-708, 2011. ,
DOI : 10.3182/20110828-6-IT-1002.00798
Finite-time stability of homogeneous systems, Proceedings of the 1997 American Control Conference (Cat. No.97CH36041), pp.2513-2514, 1997. ,
DOI : 10.1109/ACC.1997.609245
Finite Time Stability and Quasihomogeneous Control Synthesis of Uncertain Switched Systems with Application to Underactuated Manipulators, Proceedings of the 44th IEEE Conference on Decision and Control, pp.4566-4571, 2005. ,
DOI : 10.1109/CDC.2005.1582882
Finite time stability and stabilization of a class of continuous systems, Journal of Mathematical Analysis and Applications, vol.323, issue.2, pp.1430-1443, 2006. ,
DOI : 10.1016/j.jmaa.2005.11.046
Stabilization via homogeneous feedback controls, Automatica, vol.44, issue.11, pp.2981-2984, 2008. ,
DOI : 10.1016/j.automatica.2008.05.003
Continuous, bounded, finite-time stabilization of the translational and rotational double integrators, Proceeding of the 1996 IEEE International Conference on Control Applications IEEE International Conference on Control Applications held together with IEEE International Symposium on Intelligent Control IEEE International Symposium on Computer-Aided Contro, pp.185-190, 1996. ,
DOI : 10.1109/CCA.1996.558628
Finite-time stabilization and stabilizability of a class of controllable systems, Systems & Control Letters, vol.46, issue.4, pp.231-236, 2002. ,
DOI : 10.1016/S0167-6911(02)00119-6
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
Semi-global finite-time observers for nonlinear systems, Automatica, vol.44, issue.12, pp.3152-3156, 2008. ,
DOI : 10.1016/j.automatica.2008.05.015
Semi-global finite-time observers for multi-output nonlinear systems, International Journal of Robust and Nonlinear Control, vol.42, issue.3, pp.789-801, 2010. ,
DOI : 10.1002/rnc.1471
A Global High-Gain Finite-Time Observer, IEEE Transactions on Automatic Control, vol.55, issue.6, pp.1500-1506, 2010. ,
DOI : 10.1109/TAC.2010.2045698
URL : https://hal.archives-ouvertes.fr/hal-00455790
On an output feedback finite-time stabilization problem, IEEE Transactions on Automatic Control, vol.46, issue.2, pp.305-309, 2001. ,
DOI : 10.1109/9.905699
Finite-time control for robot manipulators, Systems & Control Letters, vol.46, issue.4, pp.243-253, 2002. ,
DOI : 10.1016/S0167-6911(02)00130-5
Finite-time output stabilization of the double integrator, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), pp.5906-5911 ,
DOI : 10.1109/CDC.2012.6426565
URL : https://hal.archives-ouvertes.fr/hal-01056207
Lyapunov Functions and Stability in Control Theory, 2005. ,
Theory of Stability of Motion, Translation Series: Physics and Mathematics, 1952. ,
Stability of Motion, 1963. ,
Methods of A.M. Lyapunov and Their Applications, 1964. ,
Some sufficient conditions for the asymptotic stabilizability of three dimensional homogeneous polynomial systems, Proceedings of the 28th IEEE Conference on Decision and Control, pp.1366-1369, 1989. ,
DOI : 10.1109/CDC.1989.70363
On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia vuzov. Mathematica, vol.1, pp.80-88, 1958. ,
Nilpotent Approximations of Control Systems and Distributions, SIAM Journal on Control and Optimization, vol.24, issue.4, p.731, 1986. ,
DOI : 10.1137/0324045
Nilpotent Lie algebras of vector fields, J. reine angew. Math, pp.1-17, 1988. ,
Homogeneous coordinates and continuous asymptotically stabilizing feedback controls, ser. Differential Equations: Stability and Control, pp.249-260, 1991. ,
DOI : 10.1051/cocv:1997101
URL : http://archive.numdam.org/article/COCV_1997__2__13_0.pdf
Stabilizability Does Not Imply Homogeneous Stabilizability for Controllable Homogeneous Systems, SIAM Journal on Control and Optimization, vol.34, issue.5, pp.1798-1813, 1996. ,
DOI : 10.1137/S0363012994267303
GEOMETRIC HOMOGENEITY AND STABILIZATION, Proc. IFAC Nonlinear Control Symposium, pp.164-169, 1995. ,
DOI : 10.1016/B978-0-08-042371-5.50030-7
Homogeneous state feedback stabilization of homogeneous systems, Proceedings of the 39th IEEE Conference on Decision and Control (Cat. No.00CH37187), pp.3409-3414, 2000. ,
DOI : 10.1109/CDC.2000.912230
Homogeneous Stabilization for Input Affine Homogeneous Systems, IEEE Transactions on Automatic Control, vol.54, issue.9 ,
DOI : 10.1109/TAC.2009.2026865
Homogeneous Approximation, Recursive Observer Design, and Output Feedback, SIAM Journal on Control and Optimization, vol.47, issue.4, pp.1814-1850, 2008. ,
DOI : 10.1137/060675861
URL : https://hal.archives-ouvertes.fr/hal-00362707
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, issue.6, pp.467-473, 1992. ,
DOI : 10.1016/0167-6911(92)90078-7
Global stabilization of planar homogeneous polynomial systems, Nonlinear Analysis: Theory, Methods & Applications, vol.34, issue.7, pp.1097-1109, 1998. ,
DOI : 10.1016/S0362-546X(98)00030-3
To Sample or not to Sample: Self-Triggered Control for Nonlinear Systems, IEEE Transactions on Automatic Control, vol.55, issue.9, pp.2030-2042, 2010. ,
DOI : 10.1109/TAC.2010.2042980
Oscillations Conditions in Homogenous Systems, Proc. IFAC NOLCOS Symp, pp.1379-1384, 2010. ,
DOI : 10.3182/20100901-3-IT-2016.00101
URL : https://hal.archives-ouvertes.fr/hal-00561003
Generalized weighted homogeneity and state dependent time scale for linear controllable systems, Proceedings of the 36th IEEE Conference on Decision and Control, pp.4342-4347, 1997. ,
DOI : 10.1109/CDC.1997.649536
On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia vuzov. Mathematica, vol.3, issue.22, pp.157-164, 1961. ,
Nonlinear control and combinatorics of words, " in Geometry of Feedback and Optimal Control, pp.305-346, 1998. ,
Etude de quelquesprobì emes de stabilisation, 1993. ,
Quasi-continuous high-order sliding-mode controllers, IEEE Transactions on Automatic Control, vol.50, issue.11, pp.1812-1816, 2005. ,
DOI : 10.1109/TAC.2005.858646
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.218.4061
Differential Equations with Discontinuous Righthand Sides, 1988. ,
DOI : 10.1007/978-94-015-7793-9
Differential Inclusions, ser, Grundlehren der Math. Wiisenschaften, vol.264, 1984. ,
Set-Valued Analysis, ser. System & Control: Foundations & Applications, 1990. ,
Non Smooth Analysis and Application, ser. Graduate Texts in Mathematics, 1997. ,
Nonlinear Systems, ser. NJ 07458. Upper Saddle River, 1996. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
DOI : 10.1016/j.automatica.2004.11.029
On extension of homogeneity notion for differential inclusions, Proceeding of the European Control Conference, pp.2204-2209, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00801818
On settling time function and stability of vector relay systems, 2012 12th International Workshop on Variable Structure Systems, pp.149-154 ,
DOI : 10.1109/VSS.2012.6163493
On stability of motion over a finite interval of time, Journal of Applied Math. and Mechanics (PMM), vol.17, pp.529-540, 1953. ,
The problem of stability in a finite interval of time, Journal of Applied Math. and Mechanics (PMM), vol.18, pp.75-94, 1954. ,
ON THE STABILITY OF SYSTEMS DEFINED OVER A FINITE TIME INTERVAL, Proc. of the National Academy of Sciences, pp.440-448, 1965. ,
DOI : 10.1073/pnas.54.1.44
An overview of finite-time stability, " in Current Trends in Nonlinear Systems and Control, ser. Systems & Control: Foundations & Applications, pp.185-194, 2006. ,
Finite-Time Stability and Stabilization:State of the art, ser. LNCIS, pp.23-41, 2006. ,
Nonlinear Feedback Design for Fixed-Time Stabilization of Linear Control Systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
DOI : 10.1109/TAC.2011.2179869
URL : https://hal.archives-ouvertes.fr/hal-00757561
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Finite time stability of differential inclusions, IMA Journal of Mathematical Control and Information, vol.22, issue.4, pp.465-475, 2005. ,
DOI : 10.1093/imamci/dni039
Finite-time input-to-state stability and applications to finite-time control design, SIAM J. Control Optim, vol.48, issue.7, pp.4395-4418 ,
Input to state stability and allied system properties, Automation and Remote Control, vol.72, issue.8, pp.1579-1614, 2011. ,
DOI : 10.1134/S0005117911080017
URL : https://hal.archives-ouvertes.fr/hal-00639491
Input-to-state stability and interconnections of discontinuous dynamical systems, Automatica, vol.44, issue.12, pp.3079-3086, 2008. ,
DOI : 10.1016/j.automatica.2008.04.025
Integral input-to-state stability for one class of discontinuous dynamical systems, 29th Chinese Control Conference (CCC), pp.912-914, 2010. ,
Robustness of finite-time stability property for sliding modes, Proc. of 5th IFAC Symposium on System Structure and Control, pp.4-6, 2013. ,
DOI : 10.3182/20130204-3-FR-2033.00159
URL : https://hal.archives-ouvertes.fr/hal-00745673
Universal stabilization of a class of nonlinear systems with homogeneous vector fields, Systems & Control Letters, vol.26, issue.3, pp.177-184, 1995. ,
DOI : 10.1016/0167-6911(95)00013-Y
H??? control, stabilization, and input???output stability of nonlinear systems with homogeneous properties, Automatica, vol.37, issue.6, pp.819-829, 2001. ,
DOI : 10.1016/S0005-1098(01)00027-9
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, issue.12, pp.1159-1167, 2013. ,
DOI : 10.1016/j.sysconle.2013.09.004
URL : https://hal.archives-ouvertes.fr/hal-00877148
Sliding Mode Enforcement after 1990: Main Results and Some Open Problems, pp.3-57, 2011. ,
DOI : 10.1007/978-3-642-22164-4_1
Analysis of finite-time convergence by the method of Lyapunov functions in systems with second-order sliding modes, Journal of Applied Mathematics and Mechanics, vol.75, issue.3, pp.289-303, 2011. ,
DOI : 10.1016/j.jappmathmech.2011.07.006
Terminal sliding mode control of mimo linear systems, IEEE Transactions on Circuits and Systems: Part I, issue.11, pp.1065-1070, 1997. ,
Non-singular terminal sliding mode control of rigid manipulators, Automatica, vol.38, issue.12, pp.2159-2167, 2002. ,
DOI : 10.1016/S0005-1098(02)00147-4
Fast terminal sliding mode control design for nonlinear dynamic systems, IEEE Transactions on Circuits and Systems -Part I, vol.39, issue.2, pp.261-264, 2002. ,
Chattering avoidance by second-order sliding mode control, IEEE Transactions on Automatic Control, vol.43, issue.2, pp.241-246, 1998. ,
DOI : 10.1109/9.661074
Analysis of chattering in continuous sliding-mode controllers, IEEE Transactions on Automatic Control, vol.50, issue.9, pp.1442-1446, 2005. ,
DOI : 10.1109/TAC.2005.854655
Chattering Analysis, IEEE Transactions on Automatic Control, vol.55, issue.6, pp.1380-1389, 2010. ,
DOI : 10.1109/TAC.2010.2041973
Unified Lyapunov function for a finite-time stability analysis of relay second-order sliding mode control systems, IMA Journal of Mathematical Control and Information, vol.29, issue.4, pp.529-550, 2012. ,
DOI : 10.1093/imamci/dns007
Principles of 2-sliding mode design, Automatica, vol.43, issue.4, pp.576-586, 2007. ,
DOI : 10.1016/j.automatica.2006.10.008
Strict Lyapunov Functions for the Super-Twisting Algorithm, IEEE Transactions on Automatic Control, vol.57, issue.4, pp.1035-1040, 2012. ,
DOI : 10.1109/TAC.2012.2186179
Uniform Robust Exact Differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
DOI : 10.1109/TAC.2011.2160030
