Electricity load forecasting and backcasting with semi-parametric models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Forecasting Année : 2013
Raphaël Nedellec
  • Fonction : Auteur
Jairo Cugliari
Yannig Goude
  • Fonction : Auteur
  • PersonId : 871243
We sum up the methodology of the team tololo for the Global Energy Forecasting Competition 2012: Load Forecasting. Our strategy consisted of a temporal multi-scale model that combines three components. The first component was a long term trend estimated by means of non-parametric smoothing. The second was a medium term component describing the sensitivity of the electricity demand to the temperature at each time step. We use a generalized additive model to fit this component, using calendar information as well. Finally, a short term component models local behaviours. As the factors that drive this component are unknown, we use a random forest model to estimate it.
Fichier non déposé
hal-00942688 , version 1 (06-02-2014)
Raphaël Nedellec, Jairo Cugliari, Yannig Goude. Electricity load forecasting and backcasting with semi-parametric models. International Journal of Forecasting, 2013, 30 (2), pp.375-381. ⟨10.1016/j.ijforecast.2013.07.004⟩. ⟨hal-00942688⟩
207 Consultations
0 Téléchargements
