induces a 3-cycle, then we check whether T ?N + (v) contains a cycle C. If yes, we extend (T [N + (v)], C) into a (1, 1)-outdegree-splitting by Proposition 32. If not, for every w (v), we check if T ? {u, v, w} contains a cycle C(uvw) If yes for at least one choice of {u, w}, then we extend (uvw, C(uvw)) into a (1, 1)-outdegree-splitting by Proposition 32 and we return 'no' otherwise. This is valid by Lemma 34, )-findsplit runs in O(n 2 ) time ,
-strong tournament has minimum outdegree at least f T (k 1 , k 2 ) and thus admits a (k 1 , k 2 )-outdegreesplitting . Therefore, it is natural to ask the following ,
2] proved that if T is a tournament of order 8 and xy an arc in T such that T \ xy is 2-strong, then T contains an outdegree-1-splitting (V x , V y ) ,
Complementary cycles containing prescribed vertices in tournaments, Discrete Mathematics, vol.214, issue.1-3, pp.77-87, 2000. ,
DOI : 10.1016/S0012-365X(99)00198-3
Cycles in digraphs??? a survey, Journal of Graph Theory, vol.2, issue.269, pp.1-43, 1981. ,
DOI : 10.1002/jgt.3190050102
Chemins et circuits hamiltoniens des graphes complets, C.R. Acad. Sci. Paris, vol.249, pp.2151-2152, 1959. ,
Partitioning Vertices of a Tournament into Independent Cycles, Journal of Combinatorial Theory, Series B, vol.83, issue.2, pp.213-220, 2001. ,
DOI : 10.1006/jctb.2001.2048
On dominance relations and the structure of animal societies: III The condition for a score structure, The Bulletin of Mathematical Biophysics, vol.2, issue.2, pp.143-148, 1953. ,
DOI : 10.1007/BF02476378
Topics on Tournaments, 1968. ,
Packing directed circuits, Combinatorica, vol.2, issue.4, pp.535-554, 1996. ,
DOI : 10.1007/BF01271272
Three Problems on Tournaments, Annals of the New York Academy of Sciences, vol.22, issue.1 Graph Theory, pp.466-473, 1989. ,
DOI : 10.1016/0097-3165(72)90098-2
Complementary Cycles of All Lengths in Tournaments, Journal of Combinatorial Theory, Series B, vol.57, issue.1, pp.18-25, 1993. ,
DOI : 10.1006/jctb.1993.1002
Decomposing graphs under degree constraints, J. Graph Theory, vol.23, pp.31-324, 1996. ,
Disjoint cycles in digraphs, Combinatorica, vol.10, issue.3-4, pp.393-396, 1983. ,
DOI : 10.1007/BF02579195
