New interface
Journal articles
Non linear methods for Inverse Statistical Problems
Abstract : In the uncertainty treatment framework considered, the intrinsic variability of the inputs of a physical simulation model is modelled by a multivariate probability distribution. The objective is to identify this probability distribution-the dispersion of which is independent of the sample size since intrinsic variability is at stake-based on observation of some model outputs. Moreover, in order to limit the number of (usually burdensome) physical model runs inside the inversion algorithm to a reasonable level, a nonlinear approximation methodology making use of Kriging and a stochastic EM algorithm is presented. It is compared with iterated linear approximation on the basis of numerical experiments on simulated data sets coming from a simplified but realistic modelling of a dyke overflow. Situations where this nonlinear approach is to be preferred to linearisation are highlighted.
Complete list of metadata
https://hal.inria.fr/hal-00943678
Contributor : Gilles Celeux Connect in order to contact the contributor
Submitted on : Saturday, February 8, 2014 - 12:18:34 PM
Last modification on : Friday, November 18, 2022 - 9:25:22 AM
Links full text
Identifiers
Citation
Pierre Barbillon, Gilles Celeux, Agnès Grimaud, Yannick Lefebvre, Etienne Rocquigny (de). Non linear methods for Inverse Statistical Problems. Computational Statistics and Data Analysis, 2010, 55, pp.132-142. ⟨10.1016/j.csda.2010.05.030⟩. ⟨hal-00943678⟩
Share
Metrics
Record views
204
