An exponential turnpike theorem for dissipative discrete time optimal control problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2014
We investigate the exponential turnpike property for nite horizon undercounted discrete time optimal control problems without any terminal constraints. Considering a class of strictly dissipative systems we derive a boundedness condition for an auxiliary optimal value function which implies the exponential turnpike property. Two theorems illustrate how this boundedness condition can be concluded from structural properties like controllability and stabilizability of the control system under consideration.
turnpike.pdf (333.31 Ko) Télécharger le fichier
hal-00944266 , version 1 (10-02-2014)
Tobias Damm, Lars Grüne, Marleen Stieler, Karl Worthmann. An exponential turnpike theorem for dissipative discrete time optimal control problems. SIAM Journal on Control and Optimization, 2014, 52 (3), pp.1935-1957. ⟨10.1137/120888934⟩. ⟨hal-00944266⟩
Collections
SADCO TDS-MACS
124 Consultations
343 Téléchargements
