More information on continuous time MPC can be found in the survey by The nowadays standard framework for stability and feasibility of MPC with stabilizing terminal constraints is presented in Mayne Stability of MPC without terminal constraints was proved in Grimm et al. (2005) under very general conditions, for a comparison of various such results see Grüne, for a continuous time version see Fontes Feasibility without terminal constraints is discussed in Kerrigan (2000) and Primbs and Nevisti´cNevisti´c, 2000. ,
An introduction to Nonlinear Model Predictive Contro, 21st Benelux Meeting on Systems and Control, pp.119-141, 2002. ,
A general framework to design stabilizing nonlinear model predictive controllers, Systems & Control Letters, vol.42, issue.2, pp.127-143, 2001. ,
DOI : 10.1016/S0167-6911(00)00084-0
Model predictive control: for want of a local control Lyapunov function, all is not lost, IEEE Transactions on Automatic Control, vol.50, issue.5, pp.50-546, 2005. ,
DOI : 10.1109/TAC.2005.847055
NMPC without terminal constraints, Proceedings of the IFAC Conference on Nonlinear Model Predictive Control ? NMPC'12, pp.1-13, 2012. ,
DOI : 10.3182/20120823-5-NL-3013.00030
Nonlinear Model Predictive Control. Theory and Algorithms, 2011. ,
Robust constraint satisfaction: Invariant sets and predictive control, 2000. ,
Constrained model predictive control: Stability and optimality, Automatica, vol.36, issue.6, pp.789-814, 2000. ,
DOI : 10.1016/S0005-1098(99)00214-9
Feasibility and stability of constrained finite receding horizon control, Automatica, vol.36, issue.7, pp.965-971, 2000. ,
DOI : 10.1016/S0005-1098(00)00004-2
Application of linear programming methods for the synthesis of automatic sampleddata systems, Avtomat. i Telemeh, vol.24, pp.912-920, 1963. ,
Model Predictive Control: Theory and Design, 2009. ,
