Abstract : In this paper, we provide analytical expressions of the Cramér-Rao bounds for the frequencies, damping factors, amplitudes and phases of complex exponentials in colored noise. These expressions show the explicit dependence of the bounds of each distinct parameter with respect to the amplitudes and phases, leading to readily interpretable formulae, which are then simplified in an asymptotic context. The results are presented in the general framework of the Polynomial Amplitude Complex Exponentials (PACE) model, also referred to as the quasipolynomial model in the literature, which accounts for systems involving multiple poles, and represents a signal as a mixture of complex exponentials modulated by polynomials. This work looks further and generalizes the studies previously undertaken on the exponential and the quasipolynomial models.
