Weighted maximum likelihood autoregressive and moving average spectrum modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We propose new algorithms for estimating autoregressive (AR), moving average (MA), and ARMA models in the spectral domain. These algorithms are derived from a maximum likelihood approach, where spectral weights are introduced in order to selectively enhance the accuracy on a predefined set of frequencies, while ignoring the other ones. This is of particular interest for modeling the spectral envelope of harmonic signals, whose spectrum only contains a discrete set of relevant coefficients. In the context of speech processing, our simulation results show that the proposed method provides a more accurate ARMA modeling of nasal vowels than the Durbin method.
Badeau-ICASSP2008.pdf (96.04 Ko) Télécharger le fichier
hal-00945273 , version 1 (25-03-2014)
  • HAL Id : hal-00945273 , version 1
Roland Badeau, Bertrand David. Weighted maximum likelihood autoregressive and moving average spectrum modeling. Proc. of IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP), 2008, Las Vegas, Nevada, United States. pp.3761--3764. ⟨hal-00945273⟩
161 Consultations
340 Téléchargements
