Approximated power iterations for fast subspace tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper introduces a fast implementation of the power iterations method for subspace tracking, based on an approximation less restrictive than the well known projection approximation. This algorithm guarantees the orthonormality of the estimated subspace weighting matrix at each iteration, and satisfies a global and exponential convergence property. Moreover, it outperforms many subspace trackers related to the power method, such as PAST, NIC, NP3 and OPAST, while keeping the same computational complexity.
isspa-03.pdf (134.28 Ko) Télécharger le fichier
hal-00945281 , version 1 (24-03-2014)
  • HAL Id : hal-00945281 , version 1
Roland Badeau, Gael Richard, Bertrand David, Karim Abed-Meraim. Approximated power iterations for fast subspace tracking. Proc. of the 7th International Symposium on Signal Processing and its Applications (ISSPA), 2003, Paris, France. pp.583--586. ⟨hal-00945281⟩
151 Consultations
352 Téléchargements
