Informed Source Separation Using Latent Components - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the issue of source separation in a particular informed configuration where both the sources and the mixtures are assumed to be known during a so-called encoding stage. This knowledge enables the computation of a side information which ought to be small enough to be watermarked in the mixtures. At the decoding stage, the sources are no longer assumed to be known, only the mixtures and the side information are processed to perform source separation. The proposed method models the sources jointly using latent variables in a framework close to multichannel nonnegative matrix factorization and models the mixing process as linear filtering. Separation at the decoding stage is done using generalized Wiener filtering of the mixtures. An experimental setup shows that the method gives very satisfying results with mixtures composed of many sources. A study of its performance with respect to the number of latent variables is presented.
hal-00945298 , version 1 (12-02-2014)
Antoine Liutkus, Roland Badeau, Gael Richard. Informed Source Separation Using Latent Components. Latent Variable Analysis and Signal Separation, 2010, Saint Malo, France. pp.498--505, ⟨10.1007/978-3-642-15995-4_62⟩. ⟨hal-00945298⟩
112 Consultations
0 Téléchargements
