Fault-tolerant control based on algebraic derivative estimation applied on a magnetically supported plate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Control Engineering Practice Année : 2014
A fault-tolerant control method based on algebraic derivative estimation is introduced. It is applied on an electromagnetically supported plate as an example of a nonlinear and an open-loop unstable system. The design of the closed loop control is facilitated assuming that relevant faults are identified sufficiently precisely and fast. This is justified by a novel robust model-based fault identification scheme which relies on algebraic methods for numerical differentiation. Derivative estimation parameters and fault-detection thresholds are chosen systematically based on the properties of the measurements. The experimental results show the practical usefulness of the presented methods.
Fichier non déposé
hal-00945564 , version 1 (12-02-2014)
Lothar Kiltz, Cédric Join, Mamadou Mboup, Joachim Rudolph. Fault-tolerant control based on algebraic derivative estimation applied on a magnetically supported plate. Control Engineering Practice, 2014, 26, pp.107-115. ⟨10.1016/j.conengprac.2014.01.009⟩. ⟨hal-00945564⟩
225 Consultations
0 Téléchargements
