The function field sieve, ANTS-I, pp.108-121, 1994. ,
DOI : 10.1007/3-540-58691-1_48
A Kilobit Special Number Field Sieve Factorization, Cryptology ePrint Archive Report, vol.205, 2007. ,
DOI : 10.1007/978-3-540-76900-2_1
Discrete logarithms in GF(p) -160 digits Email to the NMBRTHRY mailing list, 2007. ,
CADO-NFS, Crible Algébrique: Distribution, Optimisation -Number Field Sieve ,
Discrete logarithm in GF(2 809 ) with FFS, PKC 2014, pp.221-238, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00818124
A Heuristic Quasi-Polynomial Algorithm for Discrete Logarithm in Finite Fields of Small Characteristic, 2014. ,
DOI : 10.1007/978-3-642-55220-5_1
URL : https://hal.archives-ouvertes.fr/hal-00835446
The filtering step of discrete logarithm and integer factorization algorithms, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00734654
Exact sparse matrix-vector multiplication on GPU's and multicore architectures, Proceedings of the 4th International Workshop on Parallel and Symbolic Computation, PASCO '10, 2010. ,
DOI : 10.1145/1837210.1837224
Solving Homogeneous Linear Equations Over GF(2) via Block Wiedemann Algorithm, Mathematics of Computation, vol.62, issue.205, pp.333-350, 1994. ,
DOI : 10.2307/2153413
New directions in cryptography, IEEE Transactions on Information Theory, vol.22, issue.6, pp.644-654, 1976. ,
DOI : 10.1109/TIT.1976.1055638
Pairing-based cryptographic protocols : a survey, Cryptology ePrint Archive Report, p.64, 2004. ,
Accelerating Iterative SpMV for the Discrete Logarithm Problem Using GPUs, 2013. ,
DOI : 10.1007/978-3-319-16277-5_2
Improvements to the general number field sieve for discrete logarithms in prime fields. A comparison with the gaussian integer method, Mathematics of Computation, vol.72, issue.242, pp.72953-967, 2003. ,
DOI : 10.1090/S0025-5718-02-01482-5
URL : https://hal.archives-ouvertes.fr/hal-01102016
Analysis of Coppersmith's block Wiedemann algorithm for the parallel solution of sparse linear systems, Mathematics of Computation, 1995. ,
DOI : 10.1007/3-540-56686-4_44
Factorization of a 768-Bit RSA Modulus, Cryptology ePrint Archive, 2010. ,
DOI : 10.1007/978-3-642-14623-7_18
URL : https://hal.archives-ouvertes.fr/inria-00444693
Solution of systems of linear equations by minimized iterations, Journal of Research of the National Bureau of Standards, vol.49, issue.1, pp.33-53, 1952. ,
DOI : 10.6028/jres.049.006
Discrete logarithms in finite fields and their cryptographic significance, 1984. ,
DOI : 10.1007/3-540-39757-4_20
Reduction of Huge, Sparse Matrices over Finite Fields Via Created Catastrophes, Experimental Mathematics, vol.32, issue.2, pp.89-94, 1992. ,
DOI : 10.1080/10586458.1992.10504250
Efficient Inter-node MPI Communication Using GPUDirect RDMA for InfiniBand Clusters with NVIDIA GPUs, 2013 42nd International Conference on Parallel Processing, pp.80-89, 2013. ,
DOI : 10.1109/ICPP.2013.17
Iterative Sparse Matrix-Vector Multiplication for Integer Factorization on GPUs, pp.413-424, 2011. ,
DOI : 10.1007/978-3-642-23397-5_41
Gaussian elimination is not optimal, Numerische Mathematik, vol.13, issue.4, pp.354-356, 1969. ,
DOI : 10.1007/BF02165411
URL : http://www.digizeitschriften.de/download/PPN362160546_0013/PPN362160546_0013___log38.pdf
Subquadratic Computation of Vector Generating Polynomials and Improvement of the Block Wiedemann Algorithm, Journal of Symbolic Computation, vol.33, issue.5, pp.757-775, 2002. ,
DOI : 10.1006/jsco.2002.0533
Solving sparse linear equations over finite fields, IEEE Transactions on Information Theory, vol.32, issue.1, pp.54-62, 1986. ,
DOI : 10.1109/TIT.1986.1057137
