Convergent incremental optimization transfer algorithms: Application to tomography, IEEE Trans. Med. Imaging, pp.25-283, 2006. ,
Optimization with Sparsity-Inducing Penalties, Foundations and Trends?? in Machine Learning, vol.4, issue.1, pp.1-106, 2012. ,
DOI : 10.1561/2200000015
URL : https://hal.archives-ouvertes.fr/hal-00613125
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.231.3271
On the Convergence of Block Coordinate Descent Type Methods, SIAM Journal on Optimization, vol.23, issue.4, pp.2037-2060, 2013. ,
DOI : 10.1137/120887679
A Convergent Incremental Gradient Method with a Constant Step Size, SIAM Journal on Optimization, vol.18, issue.1, pp.29-51, 2007. ,
DOI : 10.1137/040615961
Monotonicity of quadratic-approximation algorithms, Annals of the Institute of Statistical Mathematics, vol.11, issue.4, pp.641-663, 1988. ,
DOI : 10.1007/BF00049423
Convex Analysis and Nonlinear Optimization: Theory and Examples, 2006. ,
Online algorithms and stochastic approximations, Online Learning and Neural Networks, 1998. ,
Convex Optimization, 2004. ,
Enhancing Sparsity by Reweighted ??? 1 Minimization, Journal of Fourier Analysis and Applications, vol.7, issue.3, pp.877-905, 2008. ,
DOI : 10.1007/s00041-008-9045-x
Logistic regression, AdaBoost and Bregman distances, Machine Learning, vol.48, issue.1/3, pp.253-285, 2002. ,
DOI : 10.1023/A:1013912006537
Proximal Splitting Methods in Signal Processing, Fixed-Point Algorithms for Inverse Problems in Science and Engineering, 2010. ,
DOI : 10.1007/978-1-4419-9569-8_10
URL : https://hal.archives-ouvertes.fr/hal-00643807
Signal Recovery by Proximal Forward-Backward Splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.58, issue.11, pp.1413-1457, 2004. ,
DOI : 10.1002/cpa.20042
SAGA: A fast incremental gradient method with support for non-strongly convex composite objectives, Proceedings of Advances in Neural Information Processing Systems, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01016843
Finito: A faster, permutable incremental gradient method for big data problems, Proceedings of ICML, 2014. ,
Duality and Auxiliary Functions for Bregman Distances, 2001. ,
Maximum likelihood from incomplete data via the EM algorithm, J. Roy. Statist. Soc. Ser. B, pp.39-40, 1977. ,
Adaptive subgradient methods for online learning and stochastic optimization, J. Mach. Learn. Res, vol.12, pp.2121-2159, 2011. ,
Efficient online and batch learning using forward backward splitting, J. Mach. Learn. Res, vol.10, pp.2899-2934, 2009. ,
Ordered subsets algorithms for transmission tomography, Physics in Medicine and Biology, vol.44, issue.11, pp.2835-2851, 1999. ,
DOI : 10.1088/0031-9155/44/11/311
URL : https://deepblue.lib.umich.edu/bitstream/2027.42/48964/2/m91111.pdf
LIBLINEAR: A library for large linear classification, J. Mach. Learn. Res, vol.9, pp.1871-1874, 2008. ,
Mean shift is a bound optimization, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.3, pp.471-474, 2005. ,
DOI : 10.1109/TPAMI.2005.59
Recovering Sparse Signals With a Certain Family of Nonconvex Penalties and DC Programming, IEEE Transactions on Signal Processing, vol.57, issue.12, pp.4686-4698, 2009. ,
DOI : 10.1109/TSP.2009.2026004
URL : https://hal.archives-ouvertes.fr/hal-00439453
Optimal Stochastic Approximation Algorithms for Strongly Convex Stochastic Composite Optimization I: A Generic Algorithmic Framework, SIAM Journal on Optimization, vol.22, issue.4, pp.1469-1492, 2012. ,
DOI : 10.1137/110848864
Fixed-Point Continuation for $\ell_1$-Minimization: Methodology and Convergence, SIAM Journal on Optimization, vol.19, issue.3, pp.1107-1130, 2008. ,
DOI : 10.1137/070698920
Beyond the regret minimization barrier: An optimal algorithm for stochastic strongly-convex optimization, Proceedings of COLT, 2011. ,
DC Programming: Overview, Journal of Optimization Theory and Applications, vol.1, issue.1, pp.1-43, 1999. ,
DOI : 10.1023/A:1021765131316
Majorization for CRFs and latent likelihoods, Proceedings of Advances in Neural Information Processing Systems, 2012. ,
First order methods for nonsmooth convex large-scale optimization, Optimization for Machine Learning, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00981863
Variational bounds for mixed-data factor analysis, Proceedings of Advances in Neural Information Processing Systems, 2010. ,
An optimal method for stochastic composite optimization, Mathematical Programming, vol.24, issue.1-2, pp.365-397, 2012. ,
DOI : 10.1007/s10107-010-0434-y
Optimization Transfer Using Surrogate Objective Functions, Journal of Computational and Graphical Statistics, vol.68, issue.1, pp.1-20, 2000. ,
DOI : 10.1080/10618600.2000.10474858
A stochastic gradient method with an exponential convergence rate for finite training sets, Proceedings of Advances in Neural Information Processing Systems, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00674995
Algorithms for non-negative matrix factorization, Proceedings of Advances in Neural Information Processing Systems, 2001. ,
Online learning for matrix factorization and sparse coding, J. Mach. Learn. Res, vol.11, pp.19-60, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00408716
Fonctions convexes duales et points proximaux dans un espace hilbertien, C. R. Acad. Sci. Paris Sér. A Math, vol.255, pp.2897-2899, 1962. ,
A View of the Em Algorithm that Justifies Incremental, Sparse, and other Variants, Learning in Graphical Models, pp.355-368, 1998. ,
DOI : 10.1007/978-94-011-5014-9_12
Robust Stochastic Approximation Approach to Stochastic Programming, SIAM Journal on Optimization, vol.19, issue.4, pp.1574-1609, 2009. ,
DOI : 10.1137/070704277
URL : https://hal.archives-ouvertes.fr/hal-00976649
Introductory Lectures on Convex Optimization, 2004. ,
DOI : 10.1007/978-1-4419-8853-9
Gradient methods for minimizing composite functions, Mathematical Programming, vol.51, issue.1, pp.125-161, 2012. ,
DOI : 10.1007/s10107-012-0629-5
Numerical Optimization, 2006. ,
DOI : 10.1007/b98874
A Unified Convergence Analysis of Block Successive Minimization Methods for Nonsmooth Optimization, SIAM Journal on Optimization, vol.23, issue.2, pp.1126-1153, 2013. ,
DOI : 10.1137/120891009
A Stochastic Successive Minimization Method for Nonsmooth Nonconvex Optimization, 2013. ,
Convergence rates of inexact proximal-gradient methods for convex optimization, Proceedings of Advances in Neural Information Processing Systems, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00618152
Minimizing Finite Sums with the Stochastic Average Gradient, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00860051
Simultaneous Variable Selection, Technometrics, vol.47, issue.3, pp.47-349, 2005. ,
DOI : 10.1198/004017005000000139
Graphical Models, Exponential Families, and Variational Inference, Foundations and Trends?? in Machine Learning, vol.1, issue.1???2, pp.1-305, 2008. ,
DOI : 10.1561/2200000001
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.192.2462
Sparse Reconstruction by Separable Approximation, IEEE Transactions on Signal Processing, vol.57, issue.7, pp.2479-2493, 2009. ,
DOI : 10.1109/TSP.2009.2016892
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.115.9334
Dual averaging methods for regularized stochastic learning and online optimization, J. Mach. Learn. Res, vol.11, pp.2543-2596, 2010. ,
Model selection and estimation in regression with grouped variables, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.58, issue.1, pp.49-67, 2006. ,
DOI : 10.1198/016214502753479356
Fast stochastic alternating direction method of multipliers, Proceedings of ICML, 2014. ,
