A model of learners profiles management process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Our research concerns teaching assistant systems. It deals with the question of reuse and exploitation of learners profiles by the different actors of the learning situation; teacher, learner, families, institution or scientist. This paper first describes the difficulties linked to the reuse of heterogeneous existing learners profiles. Then, REPro, a learners profiles management model is proposed. The deployment of this process within a computerized environment is presented as well as the results of first experiments.
AIED2009_CE_REPro.pdf (1.49 Mo) Télécharger le fichier
hal-00948777 , version 1 (11-06-2021)
  • HAL Id : hal-00948777 , version 1
Carole Eyssautier-Bavay, Stéphanie Jean-Daubias, Jean-Philippe Pernin. A model of learners profiles management process. Artificiel Intelligence In Education Proceedings, 2009, Brighton, United Kingdom. pp.265-272. ⟨hal-00948777⟩
526 Consultations
53 Téléchargements
