Language Definitions as Rewrite Theories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
K is a formal framework for defining the operational semantics of programming languages. It includes software tools for compiling K language definitions to Maude rewrite theories, for executing programs in the defined languages based on the Maude rewriting engine, and for analyzing programs by adapting various Maude analysis tools. A recent extension to the K tool suite is an automatic transformation of language definitions that enables the symbolic execution of programs, i.e., the execution of programs with symbolic inputs. In this paper we investigate the theoretical relationships between K language definitions and their translations to Maude, between symbolic extensions of K definitions and their Maude encodings, and how the relations between K definitions and their symbolic extensions are reflected on their respective representations in Maude. These results show, in particular, how analyses performed with Maude tools can be formally lifted up to the original language definitions.
wrla2014.pdf (291.37 Ko) Télécharger le fichier
hal-00950775 , version 1 (22-02-2014)
  • HAL Id : hal-00950775 , version 1
Andrei Arusoaie, Dorel Lucanu, Vlad Rusu, Traian-Florin Serbanuta, Andrei Stefanescu, et al.. Language Definitions as Rewrite Theories. International Workshop on Rewriting Logic and Application, Apr 2014, Grenoble, France. ⟨hal-00950775⟩
236 Consultations
225 Téléchargements
