A Lagrangian Discontinuous Galerkintype method on unstructured meshes to solve hydrodynamics problems, Int. J. Numer. Meth. Fluids, vol.44, pp.645-663, 2004. ,
A compatible finite element multi-material ALE hydrodynamics algorithm, International Journal for Numerical Methods in Fluids, vol.141, issue.8, pp.953-964, 2008. ,
DOI : 10.1002/fld.1593
A high order cell centred dual grid Lagrangian Godunov scheme. Computers and Fluids, pp.15-24, 2013. ,
Isogeometric analysis of Lagrangian hydrodynamics, Journal of Computational Physics, vol.243, pp.224-243, 2013. ,
DOI : 10.1016/j.jcp.2013.02.021
Extension of ALE methodology to unstructured conical meshes, ESAIM: Proceedings, pp.1-10, 2011. ,
DOI : 10.1051/proc/2011011
URL : https://hal.archives-ouvertes.fr/hal-00777271
A cell-centered Lagrangian Godunov-like method for solid dynamics, Computers & Fluids, vol.83, pp.33-47, 2013. ,
DOI : 10.1016/j.compfluid.2012.09.008
The Construction of Compatible Hydrodynamics Algorithms Utilizing Conservation of Total Energy, Journal of Computational Physics, vol.146, issue.1, pp.227-262, 1998. ,
DOI : 10.1006/jcph.1998.6029
Elimination of Artificial Grid Distortion and Hourglass-Type Motions by Means of Lagrangian Subzonal Masses and Pressures, Journal of Computational Physics, vol.142, issue.2, pp.521-561, 1998. ,
DOI : 10.1006/jcph.1998.5952
A cell-centered Lagrangian hydrodynamics scheme on general unstructured meshes in arbitrary dimension, Journal of Computational Physics, vol.228, issue.14, pp.5160-5183, 2009. ,
DOI : 10.1016/j.jcp.2009.04.015
A high order ENO conservative Lagrangian type scheme for the compressible Euler equations, Journal of Computational Physics, vol.227, issue.2, pp.1567-1596, 2007. ,
DOI : 10.1016/j.jcp.2007.09.017
A third-order conservative Lagrangian type scheme on curvilinear meshes for the compressible Euler equations, Commun. Comput. Phys, vol.4, pp.1008-1024, 2008. ,
The Runge-Kutta local projection discontinuous Galerkin finite element method for conservation laws IV: The multidimensional case, Math. Comp, vol.54, pp.545-581, 1990. ,
TVB Runge-Kutta local projection discontinuous Galerkin finite element method for conservation laws III: One-dimensional systems, Journal of Computational Physics, vol.84, issue.1, pp.90-113, 1989. ,
DOI : 10.1016/0021-9991(89)90183-6
Lagrangian Gas Dynamics in Two Dimensions and Lagrangian systems, Archive for Rational Mechanics and Analysis, vol.180, issue.3, pp.327-372, 2005. ,
DOI : 10.1007/s00205-005-0375-4
Curvilinear finite elements for Lagrangian hydrodynamics, International Journal for Numerical Methods in Fluids, vol.72, issue.1, pp.11-121295, 2011. ,
DOI : 10.1002/fld.2366
High-Order Curvilinear Finite Element Methods for Lagrangian Hydrodynamics, SIAM Journal on Scientific Computing, vol.34, issue.5, pp.606-641, 2012. ,
DOI : 10.1137/120864672
High Order Curvilinear Finite Elements for axisymmetric Lagrangian Hydrodynamics. Computers and Fluids, pp.58-69, 2013. ,
Mécanique, volume I. Ellipses, 1986. ,
WAT: A Numerical Method for Two-Dimensional Unsteady Fluid Flow, 1960. ,
On the theory of semi-implicit projection methods for viscous incompressible flow and its implementation via a finite element method that also introduces a nearly consistent mass matrix. Part 2: Implementation, International Journal for Numerical Methods in Fluids, vol.7, issue.5, 1990. ,
DOI : 10.1002/fld.1650110510
The Mechanics and Thermodynamics of Continua, 2009. ,
DOI : 10.1017/CBO9780511762956
A new high-order discontinuous Galerkin spectral finite element method for Lagrangian gas dynamics in two-dimensions, Journal of Computational Physics, vol.230, issue.7, pp.2496-2522, 2011. ,
DOI : 10.1016/j.jcp.2010.12.023
On efficient generation of numerically robust Sedov solutions, 2007. ,
Discretization of hyperelasticity on unstructured mesh with a cell-centered Lagrangian scheme, Journal of Computational Physics, vol.229, issue.24, pp.9092-9118, 2010. ,
DOI : 10.1016/j.jcp.2010.08.024
A tensor artificial viscosity using a finite element approach, J. Comp. Phys, vol.228, pp.8336-8366, 2010. ,
A vertex-based hierarchical slope limiter for <mml:math altimg="si27.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>p</mml:mi></mml:math>-adaptive discontinuous Galerkin methods, Journal of Computational and Applied Mathematics, vol.233, issue.12, pp.3077-3085, 2009. ,
DOI : 10.1016/j.cam.2009.05.028
Application de la méthode des éléments finis en hydrodynamique bi-dimensionnelle utilisant les variables de Lagrange, 1972. ,
Application of the Finite Element Method to 2D Lagrangian hydrodynamics In Finite element methods in flow problems, Proceedings of the International Symposium, pp.139-152, 1974. ,
Une Méthode Particulaire Lagrangienne de type Galerkin Discontinu Application à la Mécanique des Fluides et l'Interaction Laser/Plasma, 2002. ,
3D staggered Lagrangian hydrodynamics scheme with cell-centered Riemann solver-based artificial viscosity, International Journal for Numerical Methods in Fluids, vol.72, issue.1, pp.22-42, 2013. ,
DOI : 10.1002/fld.3730
A discontinuous Galerkin method based on a Taylor basis for the compressible flows on arbitrary grids, Journal of Computational Physics, vol.227, issue.20, pp.8875-8893, 2008. ,
DOI : 10.1016/j.jcp.2008.06.035
A high-order cell-centered Lagrangian scheme for two-dimensional compressible fluid flows on unstructured meshes, Journal of Computational Physics, vol.228, issue.7, pp.2391-2425, 2009. ,
DOI : 10.1016/j.jcp.2008.12.007
URL : https://hal.archives-ouvertes.fr/inria-00322369
A high-order one-step sub-cell force-based discretization for cellcentered Lagrangian hydrodynamics on polygonal grids . Computers and Fluids, pp.479-485, 2011. ,
A Cell-Centered Lagrangian Scheme for Two-Dimensional Compressible Flow Problems, SIAM Journal on Scientific Computing, vol.29, issue.4, pp.1781-1824, 2007. ,
DOI : 10.1137/050633019
URL : https://hal.archives-ouvertes.fr/inria-00334022
Abstract, Communications in Computational Physics, vol.146, issue.04, pp.940-978, 2011. ,
DOI : 10.1016/j.jcp.2005.11.022
Sur la structure mathématique et l'approximation numérique de l'hydrodynamique Lagrangienne bidimensionelle, 2007. ,
Errors for calculations of strong shocks using an artificial viscosity and an artificial heat flux, Journal of Computational Physics, vol.72, issue.1, pp.78-120, 1987. ,
DOI : 10.1016/0021-9991(87)90074-X
A curvilinear finite-volume method to solve compressible gas dynamics in semi-Lagrangian coordinates, Comptes Rendus Mathematique, vol.348, issue.17-18, pp.1027-1032, 2010. ,
DOI : 10.1016/j.crma.2010.08.006
A conservative Eulerian formulation of the equations for elastic flow, Advances in Applied Mathematics, vol.9, issue.4, pp.481-499, 1988. ,
DOI : 10.1016/0196-8858(88)90025-5
Stabilized shock hydrodynamics: II. Design and physical interpretation of the SUPG operator for Lagrangian computations, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.4-6, pp.966-978, 2007. ,
DOI : 10.1016/j.cma.2006.08.009
Stabilized shock hydrodynamics: I. A Lagrangian method, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.4-6, pp.923-966, 2007. ,
DOI : 10.1016/j.cma.2006.08.008
Multi-scale Lagrangian shock hydrodynamics on Q1/P0 finite elements: Theoretical framework and two-dimensional computations, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.9-12, pp.1056-1079, 2008. ,
DOI : 10.1016/j.cma.2007.10.002
Efficient implementation of essentially non-oscillatory shock-capturing schemes, Journal of Computational Physics, vol.77, issue.2, pp.439-471, 1988. ,
DOI : 10.1016/0021-9991(88)90177-5
A survey of several finite difference methods for systems of nonlinear hyperbolic conservation laws, Journal of Computational Physics, vol.27, issue.1, pp.1-31, 1978. ,
DOI : 10.1016/0021-9991(78)90023-2
Cell-centered discontinuous Galerkin discretization for twodimensional Lagrangian hydrodynamics. Computers and Fluids, pp.64-73, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01093675
Cell-centered discontinuous Galerkin discretizations for two-dimensional scalar conservation laws on unstructured grids and for one-dimensional Lagrangian hydrodynamics, Computers & Fluids, vol.46, issue.1, pp.498-604, 2010. ,
DOI : 10.1016/j.compfluid.2010.07.018
URL : https://hal.archives-ouvertes.fr/inria-00538165
Methods in Computational Physics, pp.211-263, 1964. ,
