TBX goes TEI -- Implementing a TBX basic extension for the Text Encoding Initiative guidelines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
This paper presents an attempt to customise the TEI (Text Encoding Initiative) guidelines in order to offer the possibility to incorporate TBX (TermBase eXchange) based terminological entries within any kind of TEI documents. After presenting the general historical, conceptual and technical contexts, we describe the various design choices we had to take while creating this customisation, which in turn have led to make various changes in the actual TBX serialisation. Keeping in mind the objective to provide the TEI guidelines with, again, an onomasiological model, we try to identify the best comprise in maintaining both the isomorphism with the existing TBX Basic standard and the characteristics of the TEI framework.
ArticleTBXinTEI.pdf (274.98 Ko) Télécharger le fichier
TBXBasic.rnc (169.42 Ko) Télécharger le fichier
Format : Autre
hal-00950862 , version 1 (23-02-2014)
hal-00950862 , version 2 (01-03-2014)
  • HAL Id : hal-00950862 , version 1
Laurent Romary. TBX goes TEI -- Implementing a TBX basic extension for the Text Encoding Initiative guidelines. 2014. ⟨hal-00950862v1⟩
911 Consultations
290 Téléchargements
