ACTRESS: Domain-Specific Modeling of Self-Adaptive Software Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A common approach for engineering self-adaptive software systems is to use Feedback Control Loops (FCLs). Advances have led to more explicit and safer design of some control architectures, however, there is a need for more integrated and systematic approaches that support end-to-end integration of FCLs into software systems. In this paper, we propose a tooled approach that enables researchers and engineers to design and integrate adaptation mechanisms into software systems through FCLs. It consists of a domain-specific modeling language that raises the level of abstraction on which FCLs are defined, making them amenable to automated analysis and implementation code synthesis. The language supports composition, distribution and reflection, thereby enabling coordination and composition of multiple distributed FCLs. Its use is facilitated by a modeling environment, ACTRESS, that provides support for modeling, verification and complete code generation. We report on its application to a concrete adaptation case study and also discuss resulting properties.
dads14-paper.pdf (220.89 Ko) Télécharger le fichier
hal-00951798 , version 1 (26-02-2014)
  • HAL Id : hal-00951798 , version 1
Filip Krikava, Philippe Collet, Robert France. ACTRESS: Domain-Specific Modeling of Self-Adaptive Software Architectures. Symposium On Applied Computing, Mar 2014, Gyeongju, South Korea. ⟨hal-00951798⟩
362 Consultations
741 Téléchargements
