Netquest: An Abstract Model for Pervasive Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Stéphane Grumbach
Xin Qi
Wenwu Qu
  • Fonction : Auteur
Kun Suo
  • Fonction : Auteur
Fang Wang
  • Fonction : Auteur
  • PersonId : 943974
One of the barriers to the implementation and deployment of pervasive applications is the lack of a programming abstraction for ubiquitous computing. We propose a system (i) that supports a declarative programming language, Netlog, well suited to rapid prototyping of distributed applications, (ii) which relies on an embedded DBMS, which facilitates its implementation and its portability over heterogeneous devices, and (iii) supports important functionalities such as implicit routing or adaptive behavior.
Fichier non déposé
hal-00953003 , version 1 (28-02-2014)
  • HAL Id : hal-00953003 , version 1
Michel Bauderon, Christophe Bobineau, Stéphane Grumbach, Antoine Henry, Xin Qi, et al.. Netquest: An Abstract Model for Pervasive Applications. Seventh IEEE International Conference on Pervasive Computing (Pervasive 2009), 2009, Nara, Japan. pp.467-481. ⟨hal-00953003⟩
334 Consultations
0 Téléchargements
