A New Lattice-Based Information Retrieval Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
Logic-based Information Retrieval (IR) models represent the retrieval decision as an implication d → q between a document d and a query q, where d and q are logical sentences. However, d → q is a bi- nary decision, we thus need a measure to estimate the degree to which d implies q, noted P(d → q). The main problems in the logic-based IR models are the difficulties to implement the decision algorithms and to define the uncertainty measure P as a part of the logic. In this study, we chose the Propositional Logic (PL) as the underlying framework. We propose to replace the implication d → q by the material implication d ⊃ q. However, we know that there is a mapping between PL and the lattice theory. In addition, Knuth [13] introduced the notion of degree of inclusion to quantify the ordering relations defined on lattices. There- fore, we position documents and queries on a lattice, where the ordering relation is equivalent to the material implication. In this case, the impli- cation d → q is replaced by an ordering relation between documents and queries, and the uncertainty P(d → q) is redefined using the degree of inclusion measure. This new IR model is: 1- general where it is possible to instantiate most of classical IR models depending on our lattice-based model, 2- capable to formally prove the intuition of Rijsbergen about replacing P (d → q) by P (q|d), and 3- easy to implement.
RR-LIG-038_orig.pdf (235.83 Ko) Télécharger le fichier
hal-00953097 , version 1 (03-03-2014)
  • HAL Id : hal-00953097 , version 1
Karam Abdulahhad, Jean-Pierre Chevallet, Catherine Berrut. A New Lattice-Based Information Retrieval Theory. [Research Report] RR-LIG-038, 2013, pp.24. ⟨hal-00953097⟩
133 Consultations
146 Téléchargements
