Spatio-temporal analysis of territorial changes from a multi-scale perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Geographical Information Science Année : 2011
Hélène Mathian
Jérôme Gensel
Claude Grasland
The full integration of time dimensions in GIS still represents a research challenge. A number of systems provide ways to visualise harmonised timestamped geographical data onto maps, with interpolated curves representing how these data have changed over time. However, these systems frequently mask the concerns linked to changes in territorial organisations and the harmonisation of data. In fact, the development of a territory should be considered in connection with its neighbourhood, governance and genealogy relationships. This article focuses on the difficulties linked with the ‘change of support problem’, which can arise when conducting spatio-temporal analysis of data. First, we present a data model handling the changing relationships between territories. Then, we illustrate how this model can be instantiated using examples that have taken place in Europe. We show how the model can address questions such as that of change blindness. Finally, we explain how hierarchical and genealogical relationships can be used inside an interactive cartographic tool for spatio-temporal analysis. It provides various views of the same phenomena at multiple scales, through an approach that takes into account the changes in territorial organisation.
Informatique
Fichier non déposé
hal-00953145 , version 1 (28-02-2014)
Christine Plumejeaud, Hélène Mathian, Jérôme Gensel, Claude Grasland. Spatio-temporal analysis of territorial changes from a multi-scale perspective. International Journal of Geographical Information Science, 2011, 25 (10), pp.1597-1612. ⟨10.1080/13658816.2010.534658⟩. ⟨hal-00953145⟩
141 Consultations
0 Téléchargements
