Self-explanatory user interfaces by model-driven engineering. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modern User Interfaces (UI) must deal with the increasing complexity of applications in terms of functionality as well as new properties as plasticity. The plasticity of a UI denotes its capacity of adaptation to the context of use preserving its quality. The efforts in plasticity have focused on the (meta) modeling of the UI, but the quality remains uncovered. We suggest a method for improving the quality of the UIs by providing explanations about the design of the UI itself: this is, by the use of the Self-Explanation. Self-Explanatory User Interfaces (SEUI) makes reference to the capacity of a UI to supply the end-user with all the information on the rational of the UI, about its constitution (for example, what is the purpose of this button?), its current state (why is the menu disabled?) as well as its evolution (how can I enable this feature?).
Fichier non déposé
hal-00953310 , version 1 (28-02-2014)
  • HAL Id : hal-00953310 , version 1
Alfonso García Frey. Self-explanatory user interfaces by model-driven engineering.. Proceedings of the 2nd ACM SIGCHI Symposium on Engineering Interactive Computing System, EICS 2010, 2010, Berlin, Germany. pp.341-344. ⟨hal-00953310⟩
51 Consultations
0 Téléchargements
