New interface
Reports (Research report)
Mutation analysis to evaluate Lustre program specifications in the context of model-checking
Lydie Du Bousquet 1
1 VASCO - Validation de Systèmes, Composants et Objets logiciels
LIG - Laboratoire d'Informatique de Grenoble
Abstract : Mutation analysis is a technique used to evaluate the ad- equacy of a test set with respect to a fault model. This approach is mainly used for unit testing evaluation. It is also used to produce new test data. In this paper, we apply mutation analysis in order to evaluate the accuracy of a specification in the context of reactive program verification by model-checking.
Document type :
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00953404
Contributor : Catherine Oriat Connect in order to contact the contributor
Submitted on : Monday, April 7, 2014 - 3:53:59 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:24 AM
Long-term archiving on: : Monday, July 7, 2014 - 10:40:46 AM
File
RR-LIG-007.pdf
Identifiers
  • HAL Id : hal-00953404, version 1
Collections
Citation
Lydie Du Bousquet. Mutation analysis to evaluate Lustre program specifications in the context of model-checking. [Research Report] RR-LIG-007, 2010. ⟨hal-00953404⟩
Share
Metrics
Record views
113
Files downloads
174
