E-CARe: A Process for Engineering Ubiquitous Information Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Information System Modeling and Design Année : 2013
Ubiquity in Information Systems (ISs) is a new requirement widely expressed by customers and users due to emerging and evolving communication and mobile technologies. Each IS should support a set of mobile applications used either to interact smartly with the changing environment, to provide adaptive services to customers or both. Designing ISs with highly technological risks requires a precise and appropriate development process. However, such processes fail to consider ubiquitous requirements throughout the development process. This paper tries to solve this issue by proposing a process for identifying and modeling ubiquitous requirements that can be integrated into an existing IS engineering process. This process, called E-CARe, focuses on adapting to the surrounding context; this requires detailed specification and analysis work by a context designer. E-CARe uses an event-driven logic, as dynamicity and reactivity are the major properties required from ubiquitous applications. A Model-Driven Engineering (MDE) approach is used to automate specification work. In order to test the process, a case study from the intelligent transport domain is applied as an illustration.
Fichier non déposé
hal-00953469 , version 1 (28-02-2014)
  • HAL Id : hal-00953469 , version 1
Ansem Ben Cheikh, Agnès Front, Jean-Pierre Giraudin, Stéphane Coulondre. E-CARe: A Process for Engineering Ubiquitous Information Systems. International Journal of Information System Modeling and Design, 2013, 4 (3), pp.1-31. ⟨hal-00953469⟩
109 Consultations
0 Téléchargements
