High Perfomance Interactive Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2011
This paper introduces the FlowVR suite, a set of softwares targeted at high perfomrance interactive computing, in particular virtual reality applications, to be executed on clusters. The FlowVR middle-ware supports coupling of heterogeneous parallel codes and is component oriented to favor code reuse. After introducing the FlowVR main concepts, we details the different tools associated and several applications.
Fichier non déposé
hal-00953504 , version 1 (14-03-2014)
  • HAL Id : hal-00953504 , version 1
Bruno Raffin. High Perfomance Interactive Computing. 2011. ⟨hal-00953504⟩
77 Consultations
0 Téléchargements
