Using Markov Logic Network for On-line Activity Recognition from Non-Visual Home Automation Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a Markov Logic Networks (MLN) approach for the on-line recognition of human activities in a smart home. The method recognises activity from non visual and non wearable sensors data. The classification model benefit from a logic formal representation and uses probabilistic inference to deal with uncertainty. The evaluation was carried out on a real smart home where 21 participants performed several daily activities recorded by microphones and several classical home automation sensors. The MLN approach reaches an accuracy of 85.3% while the basleine support vector machine and naive Bayes approches leads to 59.6% and 66.1% respectively. Results show not only the great abilities of MLN as a classifier but also its potential to be integrable into a formal knowledge representation framework.
2012_AMI_Chahuara.pdf (310.7 Ko) Télécharger le fichier
hal-00953512 , version 1 (28-02-2014)
  • HAL Id : hal-00953512 , version 1
Pedro Chahuara, Anthony Fleury, François Portet, Michel Vacher. Using Markov Logic Network for On-line Activity Recognition from Non-Visual Home Automation Sensors. Ambient Intelligence, Nov 2012, Pisa, Italy. pp.177--192. ⟨hal-00953512⟩
175 Consultations
530 Téléchargements
