Abstract : In this paper, a new method to locate a person using multimodal non-visual sensors and microphones in a pervasive environment is presented. The information extracted from sensors is combined using a two-level dynamic network to obtain the location hypotheses. This method was tested within two smart homes using data from experiments involving about 25 participants. The preliminary results show that an accuracy of 90% can be reached using several uncertain sources. The use of implicit localisation sources, such as speech recognition, mainly used in this project for voice command, can improv e performances in many cases.
https://hal.inria.fr/hal-00953556 Contributor : Michel VacherConnect in order to contact the contributor Submitted on : Friday, February 28, 2014 - 12:26:51 PM Last modification on : Sunday, June 26, 2022 - 9:34:55 AM Long-term archiving on: : Wednesday, May 28, 2014 - 1:15:24 PM
Pedro Chahuara, François Portet, Michel Vacher. Location of an Inhabitant for Domotic Assistance Through Fusion of Audio and Non-Visual Data. Pervasive Health, May 2011, Dublin, Ireland. pp.1-4. ⟨hal-00953556⟩
