The ARGOS campaign: Evaluation of Video Analysis Tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing: Image Communication Année : 2007
The benchmarking of various methods of video analysis and indexing has become a research problem per se. While a lot of effort nowadays is devoted to organization of evaluation campaigns both on international, such as TREC Video and national levels, an in-deep analysis of the performance of the methods still remains an open issue. Several aspects in the evaluation of methods have to be addressed: how to design a benchmarking corpus in order to cover a sufficiently wide range of applications, what are the tasks to address, what are the most relevant evaluation metrics. The Argos evaluation campaign supported by the French Techno-Vision program aimed at developing esources for a benchmarking of video content analysis and indexing methods. The paper describes the type of the evaluated tasks, the way the content set has been produced, metrics and tools developed for the evaluations and some of the results obtained at the end of the first phase. Perspectives based on current works will be given to conclude this paper.
Mots clés
Fichier non déposé
hal-00953801 , version 1 (28-02-2014)
  • HAL Id : hal-00953801 , version 1
Philippe Joly, Jenny Benois-Pineau, Ewa Kijak, Georges Quénot. The ARGOS campaign: Evaluation of Video Analysis Tools. Signal Processing: Image Communication, 2007, 22 (7-8), pp.705-717. ⟨hal-00953801⟩
280 Consultations
0 Téléchargements
