Image and Video Indexing using Networks of Operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Image and Video Processing Année : 2007
This article presents a framework for the design of concept detection systems for image and video indexing. This framework integrates in a homogeneous way all the data and processing types. The semantic gap is crossed in a number of steps, each producing a small increase in the abstraction level of the handled data. All the data inside the semantic gap and on both sides included are seen as a homogeneous type called \em numcept and all the processing modules between the various numcepts are seen as a homogeneous type called \em operator. Concepts are extracted from the raw signal using networks of operators operating on numcepts. These networks can be represented as data-flow graphs and the introduced homogenizations allow fusing elements regardless of their nature. Low-level descriptors can be fused with intermediate of final concepts.
Fichier non déposé
hal-00953803 , version 1 (28-02-2014)
  • HAL Id : hal-00953803 , version 1
Stéphane Ayache, Georges Quénot. Image and Video Indexing using Networks of Operators. EURASIP Journal on Image and Video Processing, 2007. ⟨hal-00953803⟩
121 Consultations
0 Téléchargements
