Particle Image Velocimetry with Optical Flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Experiments in Fluids Année : 1998
An Optical Flow technique based on the use of Dynamic Programming has been applied to Particle Image Velocimetry yielding a significant increase in the accuracy and spatial resolution of the velocity field. Results are presented for calibrated synthetic sequences of images and for sequences of real images taken for a thermally driven flow of water with a freezing front. The accuracy remains better than 0.5 pixel/frame for tested two-image sequences and 0.2 pixel/frame for four-image sequences, even with a 10% added noise level and allowing 10% of particles to appear or disappear. A velocity vector is obtained for every pixel of the image.
jeif98-o.pdf (996.89 Ko) Télécharger le fichier
hal-00953823 , version 1 (13-11-2019)
Georges Quénot, Jaroslaw Pakleza, Tomasz Kowalewski. Particle Image Velocimetry with Optical Flow. Experiments in Fluids, 1998, 25 (3), pp.177--189. ⟨10.1007/s003480050222⟩. ⟨hal-00953823⟩
123 Consultations
344 Téléchargements
