Conference papers
Synchronous Orthogonal Dynamic Programming for Particle Image Velocimetry
Georges Quénot 1
Abstract : This paper presents an improvement of the Orthogonal Dynamic Programming optical flow technique that permits a better use of all the available information during the iterative search of the vector field in the case of stereo PIV. The two-component apparent vector fields are computed simultaneously (synchronously) for all available viewpoints. Coherency constraints issued from the geometry of the experimental setup and based upon the existence of a global three-component vector field are applied at each global step of the iterative search. Tests carried out using the Standard Images from the Visualization Society of Japan shows a small improvement in accuracy and a significant improvement in robustness.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00953956
Contributor : Marie-Christine Fauvet Connect in order to contact the contributor
Submitted on : Friday, February 28, 2014 - 4:07:49 PM
Last modification on : Sunday, June 26, 2022 - 9:35:05 AM
Identifiers
  • HAL Id : hal-00953956, version 1
Collections
Citation
Georges Quénot. Synchronous Orthogonal Dynamic Programming for Particle Image Velocimetry. Particle Image Velocimetry, Dynamic Programming., 2000, Edinburgh, Scotland, UK, pp.378.1--8. ⟨hal-00953956⟩
Share
Metrics
Record views
27
