Strategic Port Graph Rewriting: An Interactive Modelling and Analysis Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Maribel Fernandez
  • Fonction : Auteur
  • PersonId : 891587
Hélène Kirchner
We present strategic portgraph rewriting as a basis for the implementation of visual modelling and analysis tools. The goal is to facilitate the specification, analysis and simulation of complex systems, using port graphs. A system is represented by an initial graph and a collection of graph rewriting rules, together with a user-defined strategy to control the application of rules. The strategy language includes constructs to deal with graph traversal and management of rewriting positions in the graph. We give a small-step operational semantics for the language, and describe its implementation in the graph transformation and visualisation tool PORGY.
Autre [cs.OH]
main.pdf (288.79 Ko) Télécharger le fichier
hal-00954546 , version 1 (03-03-2014)
hal-00954546 , version 2 (14-03-2014)
hal-00954546 , version 3 (05-04-2014)
  • HAL Id : hal-00954546 , version 2
Maribel Fernandez, Hélène Kirchner, Bruno Pinaud. Strategic Port Graph Rewriting: An Interactive Modelling and Analysis Framework. 2014. ⟨hal-00954546v2⟩
302 Consultations
708 Téléchargements
