Nonlinear interactions: analytical, computational and experimental methods Wiley series in nonlinear science, 2000. ,
Nonlinear vibrations and stability of shells and plates, 2008. ,
DOI : 10.1017/CBO9780511619694
Practical bifurcation and stability analysis, 2010. ,
DOI : 10.1007/978-1-4419-1740-9
Numerical continuation methods for dynamical systems, 2007. ,
DOI : 10.1007/978-1-4020-6356-5
Nonlinear oscillations, 1979. ,
Computational formulation for periodic vibration of geometrically nonlinear structures???part 2: Numerical strategy and examples, International Journal of Solids and Structures, vol.34, issue.15, pp.1949-1964, 1997. ,
DOI : 10.1016/S0020-7683(96)00126-6
Non-linear responses of suspended cables to primary resonance excitations, Journal of Sound and Vibration, vol.266, issue.2, pp.325-354, 2003. ,
DOI : 10.1016/S0022-460X(02)01393-7
NON-LINEAR DYNAMICS AND STABILITY OF CIRCULAR CYLINDRICAL SHELLS CONTAINING FLOWING FLUID, PART II: LARGE-AMPLITUDE VIBRATIONS WITHOUT FLOW, Journal of Sound and Vibration, vol.228, issue.5, pp.1103-1124, 1999. ,
DOI : 10.1006/jsvi.1999.2476
Reduced-order models for large-amplitude vibrations of shells including in-plane inertia, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.21-24, pp.21-242030, 2008. ,
DOI : 10.1016/j.cma.2008.01.002
A comparison of shell theories for large-amplitude vibrations of circular cylindrical shells: Lagrangian approach, Journal of Sound and Vibration, vol.264, issue.5, pp.1091-1125, 2003. ,
DOI : 10.1016/S0022-460X(02)01385-8
Nonlinear vibrations of shallow shells with complex boundary: R-functions method and experiments, Journal of Sound and Vibration, vol.306, issue.3-5, pp.3-5580, 2007. ,
DOI : 10.1016/j.jsv.2007.05.045
Finite element reduced order models for nonlinear vibrations of piezoelectric layered beams with applications to NEMS, Finite Elements in Analysis and Design, vol.49, issue.1, pp.35-51, 2012. ,
DOI : 10.1016/j.finel.2011.08.019
URL : https://hal.archives-ouvertes.fr/hal-01084700
Nonlinear forced vibration of damped plates by an asymptotic numerical method, Computers & Structures, vol.87, issue.23-24, pp.1508-1515, 2009. ,
DOI : 10.1016/j.compstruc.2009.07.005
URL : https://hal.archives-ouvertes.fr/hal-00494489
Nonlinear forced vibration of damped plates coupling asymptotic numerical method and reduction models, Computational Mechanics, vol.88, issue.3, pp.359-377, 2011. ,
DOI : 10.1007/s00466-010-0549-2
URL : https://hal.archives-ouvertes.fr/hal-00987126
Determination of nonlinear stiffness with application to random vibration of geometrically nonlinear structures, Computers & Structures, vol.81, issue.15, pp.1513-1523, 2003. ,
DOI : 10.1016/S0045-7949(03)00145-7
Stochastic reduced order models for uncertain geometrically nonlinear dynamical systems, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.45-48, pp.3951-3963, 2008. ,
DOI : 10.1016/j.cma.2008.03.032
URL : https://hal.archives-ouvertes.fr/hal-00686140
A review of indirect/non-intrusive reduced order modeling of nonlinear geometric structures, Journal of Sound and Vibration, vol.332, issue.10, pp.2437-2460, 2013. ,
DOI : 10.1016/j.jsv.2012.10.017
The Finite Element Analysis of Shells ? Fundamentals, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
Computational Methods in Structural Dynamics. Sijthoff and Noordhoff, The Netherlands, 1980. ,
The Proper Orthogonal Decomposition in the Analysis of Turbulent Flows, Annual Review of Fluid Mechanics, vol.25, issue.1, pp.539-575, 1993. ,
DOI : 10.1146/annurev.fl.25.010193.002543
Dimensional model reduction in non???linear finite element dynamics of solids and structures, International Journal for Numerical Methods in Engineering, vol.31, issue.4, pp.479-504, 2001. ,
DOI : 10.1002/nme.167
Reduced-order models for nonlinear vibrations of fluid-filled circular cylindrical shells: Comparison of POD and asymptotic nonlinear normal modes methods, Journal of Fluids and Structures, vol.23, issue.6, pp.885-903, 2007. ,
DOI : 10.1016/j.jfluidstructs.2006.12.004
URL : https://hal.archives-ouvertes.fr/hal-00838880
Finite Element Procedures, 1996. ,
A continuum mechanics based four???node shell element for general non???linear analysis, Engineering Computations, vol.1, issue.1, pp.77-88, 1984. ,
DOI : 10.1108/eb023562
Asymptotic and spectral properties of a class of singular-stiff problems, J. Math. Pures Appl, vol.71, pp.379-406, 1992. ,
Free vibrations for some Koiter shells of revolution, Applied Mathematics Letters, vol.21, issue.12, pp.1245-1248, 2008. ,
DOI : 10.1016/j.aml.2007.10.030
The Normal Modes of Nonlinear n-Degree-of-Freedom Systems, Journal of Applied Mechanics, vol.29, issue.1, pp.7-14, 1962. ,
DOI : 10.1115/1.3636501
URL : https://hal.archives-ouvertes.fr/hal-01344457
On Nonlinear Vibrations of Systems with Many Degrees of Freedom, Advances in Applied Mechanics, vol.9, pp.155-242, 1966. ,
DOI : 10.1016/S0065-2156(08)70008-5
Normal modes and localization in non-linear systems, 1996. ,
NON-LINEAR NORMAL MODES (NNMs) AND THEIR APPLICATIONS IN VIBRATION THEORY: AN OVERVIEW, Mechanical Systems and Signal Processing, vol.11, issue.1, pp.3-22, 1997. ,
DOI : 10.1006/mssp.1996.9999
URL : https://hal.archives-ouvertes.fr/hal-01354037
Nonlinear targeted energy transfer in mechanical and structural systems I, 2008. ,
Nonlinear normal modes, Part I: A useful framework for the structural dynamicist, Mechanical Systems and Signal Processing, vol.23, issue.1, pp.170-194, 2009. ,
DOI : 10.1016/j.ymssp.2008.04.002
URL : https://hal.archives-ouvertes.fr/hal-01357931
Auto 2000: Continuation and bifurcation software for ordinary differential equations, 2002. ,
Transition to chaotic vibrations for harmonically forced perfect and imperfect circular plates, International Journal of Non-Linear Mechanics, vol.46, issue.1, pp.234-246, 2011. ,
DOI : 10.1016/j.ijnonlinmec.2010.09.004
Transition scenario to turbulence in thin vibrating plates, Journal of Sound and Vibration, vol.331, issue.2, pp.412-433, 2012. ,
DOI : 10.1016/j.jsv.2011.09.016
Nonlinear dynamics of rectangular plates: investigation of modal interaction in free and forced vibrations, Acta Mechanica, vol.26, issue.1, 2013. ,
DOI : 10.1007/s00707-013-0931-1
URL : https://hal.archives-ouvertes.fr/hal-01134793
Nonlinear normal modes, Part II: Toward a practical computation using numerical continuation techniques, Mechanical Systems and Signal Processing, vol.23, issue.1, pp.195-216, 2009. ,
DOI : 10.1016/j.ymssp.2008.04.003
Nonlinear Normal Modes of a Full-Scale Aircraft, 29th International Modal Analysis Conference, 2011. ,
DOI : 10.1007/978-1-4419-9299-4_19
On the numerical computation of nonlinear normal modes for reduced-order modelling of conservative vibratory systems, Mechanical Systems and Signal Processing, vol.36, issue.2, pp.520-539, 2013. ,
DOI : 10.1016/j.ymssp.2012.10.016
URL : https://hal.archives-ouvertes.fr/hal-00772317
Geometric numerical integration: structurepreserving algorithms for Ordinary differential equations, 2006. ,
On the discretization of distributed-parameter systems with quadratic and cubic non-linearities, Nonlinear Dynamics, vol.13, issue.3, pp.203-220, 1997. ,
DOI : 10.1023/A:1008253901255
Reduction methods for nonlinear vibrations of spatially continuous systems with initial curvature. Solid Mechanics and its applications, pp.235-246, 2000. ,
NON-LINEAR DYNAMICS AND STABILITY OF CIRCULAR CYLINDRICAL SHELLS CONTAINING FLOWING FLUID. PART III: TRUNCATION EFFECT WITHOUT FLOW AND EXPERIMENTS, Journal of Sound and Vibration, vol.237, issue.4, pp.617-640, 2000. ,
DOI : 10.1006/jsvi.2000.3071
Hardening/softening behaviour in non-linear oscillations of structural systems using non-linear normal modes, Journal of Sound and Vibration, vol.273, issue.1-2, pp.77-101, 2004. ,
DOI : 10.1016/j.jsv.2003.04.005
On methods for continuous systems with quadratic and cubic nonlinearities, Nonlinear Dynamics, vol.89, issue.2, pp.145-162, 1992. ,
DOI : 10.1007/BF00118990
Analysis of One-to-One Autoparametric Resonances in Cables ??? Discretization vs. Direct Treatment, Nonlinear Dynamics, vol.8, pp.65-83, 1995. ,
DOI : 10.1007/978-94-011-0367-1_4
Non-linear vibrations of doubly curved shallow shells, International Journal of Non-Linear Mechanics, vol.40, issue.5, pp.683-710, 2005. ,
DOI : 10.1016/j.ijnonlinmec.2004.08.007
Non-linear behaviour of free-edge shallow spherical shells: Effect of the geometry, International Journal of Non-Linear Mechanics, vol.41, issue.5, pp.678-692, 2006. ,
DOI : 10.1016/j.ijnonlinmec.2005.12.004
Non-linear normal modes and invariant manifolds, Journal of Sound and Vibration, vol.150, issue.1, pp.170-173, 1991. ,
DOI : 10.1016/0022-460X(91)90412-D
URL : https://hal.archives-ouvertes.fr/hal-01310674
Non-linear normal modes for damped geometrically nonlinear systems: application to reduced-order modeling of harmonically forced structures, Journal of Sound and Vibration, vol.298, pp.4-5958, 2006. ,
