Non-singular assembly mode changing trajectories in the workspace for the 3-RPS parallel robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
Having non-singular assembly modes changing trajectories for the 3-RPS parallel robot is a well-known feature. The only known solution for defining such trajectory is to encircle a cusp point in the joint space. In this paper, the aspects and the characteristic surfaces are computed for each operation mode to define the uniqueness of the domains. Thus, we can easily see in the workspace that at least three assembly modes can be reached for each operation mode. To validate this property, the mathematical analysis of the determinant of the Jacobian is done. The image of these trajectories in the joint space is depicted with the curves associated with the cusp points.
Chablat_2014.pdf (804.87 Ko) Télécharger le fichier
hal-00956325 , version 1 (06-03-2014)
Damien Chablat, Ranjan Jha, Fabrice Rouillier, Guillaume Moroz. Non-singular assembly mode changing trajectories in the workspace for the 3-RPS parallel robot. Jadran Lenarčič, Oussama Khatib. Advances in Robot Kinematics, Springer, pp.149 - 159, 2014, 978-3-319-06697-4. ⟨hal-00956325⟩
664 Consultations
413 Téléchargements
