Space-minimal systolic arrays for Gaussian elimination and the algebraic path problem, Parallel Computing, pp.15-211, 1990. ,
Parallelisation of the Gaussian elimination on systolic arrays, Journal of Parallel and Distributed Computing, pp.33-69, 1996. ,
Parallelisation of the Gauss elimination on systolic arrays, Internal Report, LRI, p.430, 1988. ,
Processor clustering for the design of optimal fixed-size systolic arrays, Proc. Sixth Int'l Parallel Processing Symp, pp.275-282, 1992. ,
Optimal mapping of systolic algorithms by regular instruction shifts, Proceedings of IEEE International Conference on Application Specific Array Processors (ASSAP'94), pp.224-235, 1990. ,
DOI : 10.1109/ASAP.1994.331801
Calculus of space-optimal mappings of systolic algorithms on processor arrays, IEEE Int. Conf. on Application Specific Array Processors, pp.591-602, 1990. ,
Synthesizing systolic arrays: Some recent developments. Int. Conf. on Application Specific Array Processors, pp.372-386, 1991. ,
Dataflow analysis of array and scalar references, International Journal of Parallel Programming, vol.24, issue.4, pp.23-53, 1991. ,
DOI : 10.1007/BF01407931
Optimal synthesis of algorithm-specific lower-dimensional processor arrays, IEEE Transactions on Parallel and Distributed Systems, vol.7, issue.3, pp.274-287, 1996. ,
DOI : 10.1109/71.491581
The loop parallilizer LooPo, Proc. Sixth Workshop On Compilers For Parallel Computers, M. Gerndt Konferenzen des Forschungszentrums Jülich, pp.311-320, 1996. ,
The design, implementation, and evaluation of a banded linear solver for distributed-memory parallel computers, IBM Research Report, vol.19, issue.6, p.20481, 1996. ,
DOI : 10.1007/3-540-62095-8_35
The Organization of Computations for Uniform Recurrence Equations, Journal of the ACM, vol.14, issue.3, pp.563-590, 1967. ,
DOI : 10.1145/321406.321418
Why systolic architectures?, Computer, vol.15, issue.1, pp.37-46, 1980. ,
DOI : 10.1109/MC.1982.1653825
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.643.6701
The parallel execution of DO loops, Communications of the ACM, vol.17, issue.2, pp.83-93, 1974. ,
DOI : 10.1145/360827.360844
Dynamic programming on two-dimensional systolic arrays, Information Processing Letters, vol.29, issue.2, pp.97-104, 1988. ,
DOI : 10.1016/0020-0190(88)90036-1
Triangular matrix inversion on systolic arrays, Parallel Computing, vol.14, issue.2, pp.223-228, 1990. ,
DOI : 10.1016/0167-8191(90)90110-U
Computational models and task scheduling for parallel sparse Cholesky factorization, Parallel Computing, vol.3, issue.4, pp.327-342, 1986. ,
DOI : 10.1016/0167-8191(86)90014-1
On the Analysis and Synthesis of VLSI Algorithms, IEEE Transactions on Computers, vol.31, issue.11, pp.11-1121, 1982. ,
DOI : 10.1109/TC.1982.1675929
Data compiling for systems of uniform recurrence equations. Parallel Processing Letters, pp.245-257, 1994. ,
Automatic synthesis of systolic array from uniform recurrence equations, Proc. IEEE 11th Annual International Conderence on Computer Architecture, pp.208-214, 1984. ,
The mapping of linear recurrence equations on regular arrays, Journal of VLSI signal processing systems for signal, image and video technology, vol.88, issue.1, pp.95-113, 1989. ,
DOI : 10.1007/BF02477176
URL : https://hal.archives-ouvertes.fr/inria-00075466
Synthesizing systolic arrays with control signals from recurrence equations, Distributed Computing, vol.35, issue.2, pp.88-105, 1989. ,
DOI : 10.1007/BF01558666
Synthesizing systolic arrays from recurrence equations, Parallel Computing, vol.14, issue.2, pp.163-189, 1990. ,
DOI : 10.1016/0167-8191(90)90105-I
Synthesis of processors arrays for the algebraic path problem: unifying old results and deriving new architectures, Parallel Processing Letters, pp.19-28, 1991. ,
Methode de conception d'algorithmes paralleles pour reseaux reguliers, Technique et Science Informatiques, vol.8, pp.63-72, 1989. ,
Time optimal linear schedules for algorithms with uniform dependencies, IEEE Transactions on Computers, vol.40, issue.6, pp.723-742, 1991. ,
DOI : 10.1109/12.90251
Derivation of systolic algorithms for the algebraic path problem by recurrence transformations, Parallel Computing, vol.26, issue.11, pp.1429-1445, 2000. ,
DOI : 10.1016/S0167-8191(00)00039-9
SCHEDULING OF THE DAG ASSOCIATED WITH PIPELINE INVERSION OF TRIANGULAR MATRICES, Parallel Processing Letters, vol.06, issue.01, pp.13-26, 1996. ,
DOI : 10.1142/S0129626496000030
A NEW ALGORITHM FOR DYNAMIC PROGRAMMING ON REGULAR ARRAYS, Parallel Processing Letters, vol.10, issue.01, pp.15-27, 2000. ,
DOI : 10.1142/S0129626400000044
Contribution to the Synthesis of Optimal Algorithms for Regular Arrays, Thèse de Doctorat, 1997. ,
Parallel Computation on regular arrays, 1992. ,
Resource constrained scheduling of uniform algorithms, Journal of VLSI signal processing systems for signal, image and video technology, vol.22, issue.3, pp.295-310, 1995. ,
DOI : 10.1007/BF02120034
Optimization of processor count for systolic arrays, Research Report, p.697, 1989. ,
Space-optimal linear processor allocation for systolic arrays synthesis, Proceedings Sixth International Parallel Processing Symposium, pp.275-282, 1992. ,
DOI : 10.1109/IPPS.1992.223033
BOUNDED BROADCAST IN SYSTOLIC ARRAYS, International Journal of High Speed Computing, vol.06, issue.02, pp.88-101, 1998. ,
DOI : 10.1142/S0129053394000111
