State space search with prioritised soft constraints, Applied Intelligence, vol.14, issue.3, pp.263-272, 2001. ,
DOI : 10.1023/A:1011242703014
Unbounded knapsack problem: Dynamic programming revisited, European Journal of Operational Research, vol.123, issue.2, pp.394-407, 2000. ,
DOI : 10.1016/S0377-2217(99)00265-9
The longest common subsequence problem revisited, Algorithmica, vol.21, issue.1-4, pp.315-336, 1987. ,
DOI : 10.1007/BF01840365
On the variance of the number of maxima in random vectors and its applications, Annals of Applied Probability, vol.8, pp.886-895, 1998. ,
Limit Theorems for the Number of Maxima in Random Samples from Planar Regions, Electronic Journal of Probability, vol.6, issue.0, p.41, 2001. ,
DOI : 10.1214/EJP.v6-76
Berry-Esseen Bounds for the Number of Maxima in Planar Regions, Electronic Journal of Probability, vol.8, issue.0, p.26, 2003. ,
DOI : 10.1214/EJP.v8-137
Algorithms for drawing graphs: an annotated bibliography, Computational Geometry: Theory and Applications, vol.4, pp.235-282, 1994. ,
Analysis of Data from the Places Rated Almanac, The American Statistician, vol.41, issue.3, pp.41-169, 1987. ,
DOI : 10.2307/2685098
Multidimensional divide-and-conquer, Communications of the ACM, vol.23, issue.4, pp.214-229, 1980. ,
DOI : 10.1145/358841.358850
Fast linear expected-time algorithms for computing maxima and convex hulls, Algorithmica, vol.20, issue.2, pp.168-183, 1993. ,
DOI : 10.1007/BF01188711
On the Average Number of Maxima in a Set of Vectors and Applications, Journal of the ACM, vol.25, issue.4, pp.536-543, 1978. ,
DOI : 10.1145/322092.322095
Divide and conquer for linear expected time, Information Processing Letters, vol.7, issue.2, pp.87-91, 1978. ,
DOI : 10.1016/0020-0190(78)90051-0
Winnowing Sequences from a Database Search, Journal of Computational Biology, vol.7, issue.1-2, pp.293-302, 2000. ,
DOI : 10.1089/10665270050081531
Rectilinear 2-center problems, Proceedings of the 11th Canadian Conference on Computational Geometry (CCCG'99), pp.68-71, 1999. ,
Random inequality constraint systems with few variables, Mathematical Programming, pp.135-139, 1986. ,
DOI : 10.1007/BF01580644
Random linear programs with many variables and few constraints, Mathematical Programming, pp.62-71, 1986. ,
DOI : 10.1007/BF01582163
More output-sensitive geometric algorithms (extended abstract), IEEE 35th Annual Symposium on Foundations of Computer Science, pp.695-702, 1994. ,
A DEA model for the efficiency evaluation of nondominated paths on a road network, European Journal of Operational Research, vol.121, issue.3, pp.549-558, 2000. ,
DOI : 10.1016/S0377-2217(99)00053-3
Evolutionary Algorithms for Solving Multiobjective Problems, 2002. ,
On Computing the Pareto Optimal Solution Set in a Large Scale Dynamic Network, 2002. ,
Multiobjective transportation problem with interval cost, source and destination parameters, European Journal of Operational Research, vol.117, issue.1, pp.100-112, 1999. ,
DOI : 10.1016/S0377-2217(98)00044-7
Multiobjective Heuristic Search: An Introduction to Intelligent Search Methods for Multicriteria Optimization, 1999. ,
DOI : 10.1007/978-3-322-86853-4
Momentenungleichungen f??r Zufallsvariable bei geometrischen Berechnungsverfahren, Computing, vol.1, issue.2, pp.30-111, 1983. ,
DOI : 10.1007/BF02280782
A note on the expected time required to construct the outer layer, Information Processing Letters, vol.20, issue.5, pp.255-257, 1985. ,
DOI : 10.1016/0020-0190(85)90028-6
A Note on the Expected Time for Finding Maxima by List Algorithms, Algorithmica, vol.23, issue.2, pp.97-108, 1999. ,
DOI : 10.1007/PL00009256
Dominance in multi-dimensional multiple-choice knapsack problems, Asia-Pacific Journal of Operational Research, vol.15, pp.159-168, 1998. ,
On the equivalence of some rectangle problems, Information Processing Letters, vol.14, issue.3, pp.124-127, 1982. ,
DOI : 10.1016/0020-0190(82)90068-0
Multicriteria Optimization, 2000. ,
DOI : 10.1007/978-3-662-22199-0
Exact asymptotics of divide-and-conquer recurrences, Lecture Notes in Computer Science, vol.700, pp.137-149, 1993. ,
DOI : 10.1007/3-540-56939-1_68
Interval finding and its application to data mining, IEICE Transaction on Fundamentals of Electronics Communications and Computer Sciences, pp.80-620, 1997. ,
DOI : 10.1007/BFb0009481
Recognition of Genes in Human DNA Sequences, Journal of Computational Biology, vol.3, issue.2, pp.223-234, 1996. ,
DOI : 10.1089/cmb.1996.3.223
A Generalization of Dynamic Programming for Pareto Optimization in Dynamic Networks, RAIRO - Operations Research, vol.34, issue.1, pp.27-47, 2000. ,
DOI : 10.1051/ro:2000100
A provably fast linear-expected-time maxima-finding algorithm, Algorithmica, pp.501-524, 1994. ,
Rough approximation by dominance relations, International Journal of Intelligent Systems, vol.1, issue.2, pp.153-171, 2002. ,
DOI : 10.1002/int.10014
Fast algorithms for direct enclosures and direct dominances, Journal of Algorithms, vol.10, issue.2, pp.170-186, 1989. ,
DOI : 10.1016/0196-6774(89)90011-4
Algorithms for the longest common subsequence problem for multiple strings based on geometric maxima, Optimization Methods and Software, pp.233-260, 1998. ,
Pareto-optimal methods for gene analysis, preprint, 2002. ,
A note on dominance in unbounded knapsack problems, Asia-Pacific Journal of Operational Research, vol.12, pp.145-160, 1995. ,
On the vector representation of the reachability in planar directed graphs, Information Processing Letters, vol.3, issue.3, pp.75-77, 1975. ,
DOI : 10.1016/0020-0190(75)90019-8
Dynamic Maintenance of Maxima of 2-d Point Sets, SIAM Journal on Computing, vol.29, issue.6, pp.1858-1877, 2000. ,
DOI : 10.1137/S0097539798348365
PICO: automatically designing custom computers, Computer, vol.35, issue.9, pp.9-39, 2002. ,
DOI : 10.1109/MC.2002.1033026
Output-size sensitive algorithms for finding maximal vectors, Proceedings of the first annual symposium on Computational geometry , SCG '85, pp.89-96, 1985. ,
DOI : 10.1145/323233.323246
Mathematical analysis of algorithms, IFIP Congress, pp.19-27, 1971. ,
The Art of Computer Programming Sorting and Searching, Second Edition, 1998. ,
On Finding the Maxima of a Set of Vectors, Journal of the ACM, vol.22, issue.4, pp.469-476, 1975. ,
DOI : 10.1145/321906.321910
Timing optimization for multisource nets: characterization and optimal repeater insertion, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.18, issue.3, pp.322-331, 1999. ,
DOI : 10.1109/43.748162
Analytic variations on bucket selection and sorting, Acta Informatica, vol.36, issue.9-10, pp.735-760, 2000. ,
DOI : 10.1007/s002360050173
URL : https://hal.archives-ouvertes.fr/inria-00073290
Partial order bounding: A new approach to evaluation in game tree search, Artificial Intelligence, vol.129, issue.1-2, pp.279-311, 2001. ,
DOI : 10.1016/S0004-3702(01)00085-6
Search for the maximum of a random walk, Random Structures and Algorithms, pp.275-295, 1995. ,
The Number of Outcomes in the Pareto-Optimal Set of Discrete Bargaining Games, Mathematics of Operations Research, vol.6, issue.4, pp.571-578, 1980. ,
DOI : 10.1287/moor.6.4.571
Multicriterion Decision in Management, 2000. ,
DOI : 10.1007/978-1-4615-4459-3
Computational Geometry: An Introduction, 1985. ,
DOI : 10.1007/978-1-4612-1098-6
MULTI-CRITERIA ASSESSMENT OF ECOLOGICAL PROCESS MODELS, Ecology, vol.80, issue.2, pp.80-538, 1999. ,
DOI : 10.1002/for.3980100110
Admissibility: Survey of a Concept in Progress, International Statistical Review / Revue Internationale de Statistique, vol.63, issue.1, pp.95-115, 1995. ,
DOI : 10.2307/1403779
Distribution-sensitive algorithms, Nordic Journal of Computing, vol.6, pp.194-211, 1999. ,
DOI : 10.1007/BFb0054380
Multiobjective A*, Journal of the ACM, vol.38, issue.4, pp.775-814, 1991. ,
DOI : 10.1145/115234.115368
An area minimizer for floorplans with L-shaped regions, Proceedings 1992 IEEE International Conference on Computer Design: VLSI in Computers & Processors, pp.383-386, 1992. ,
DOI : 10.1109/ICCD.1992.276295
Path problems in networks with vector-valued edge weights, Networks, pp.34-53, 1999. ,
A randomized algorithm for finding maximum with O((log n)2) polynomial tests, Information Processing Letters, vol.49, issue.1, pp.49-88, 1994. ,
DOI : 10.1016/0020-0190(94)90052-3
Risk assessment of the harvested pike-perch population of the Azov Sea, Ecological Modelling, vol.149, issue.3, pp.297-311, 2002. ,
DOI : 10.1016/S0304-3800(01)00478-1
Multiobjective Evolutionary Algorithms: Analyzing the State-of-the-Art, Evolutionary Computation, vol.8, issue.2, pp.125-147, 2000. ,
DOI : 10.1109/4235.797969
Statistical Decision Functions., Journal of the American Statistical Association, vol.46, issue.253, 1971. ,
DOI : 10.2307/2280105
Approximation of Pareto Optima in Multiple-Objective, Shortest-Path Problems, Operations Research, vol.35, issue.1, pp.70-79, 1987. ,
DOI : 10.1287/opre.35.1.70
Rectilinear full Steiner tree generation, Networks, pp.33-125, 1999. ,
