On the structure of minimum weight kconnected spanning networks On two-connected subgraph polytopes, SIAM Journal on Discrete Mathematics Discrete Mathematics, vol.3, issue.147, pp.245-25919, 1990. ,
Graph theory in network design and analysis, Recent Studies in Graph Theory, pp.29-63, 1989. ,
Concerning the number of edges in a graph with diameter constraints, Journal of Combinatorial Mathematics and Combinatorial Computing, vol.36, pp.161-173, 2001. ,
Linear-time algorithms for the 2- connected Steiner subgraph problem on special classes of graphs. Networks, pp.195-206, 1993. ,
Network synthesis with connectivity constraints : a survey, Operational Research, pp.705-723, 1981. ,
Send-and-Split Method for Minimum-Concave-Cost Network Flows, Mathematics of Operations Research, vol.12, issue.4, pp.634-664, 1987. ,
DOI : 10.1287/moor.12.4.634
$(1 + \epsilon,\beta)$-Spanner Constructions for General Graphs, Proceedings of 33 rd Annual ACM Symp. on Theory of Computing, pp.173-182, 2001. ,
DOI : 10.1137/S0097539701393384
Solving the Two-Connected Network with Bounded Meshes Problem, Operations Research, vol.48, issue.6, pp.866-877, 2000. ,
DOI : 10.1287/opre.48.6.866.12390
URL : https://hal.archives-ouvertes.fr/hal-01255611
Minimum Self-Repairing Graphs, Graphs and Combinatorics, vol.7, issue.4, pp.345-351, 1997. ,
DOI : 10.1007/BF03353012
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.29.8547
Integer Polyhedra Arising from Certain Network Design Problems with Connectivity Constraints, SIAM Journal on Discrete Mathematics, vol.3, issue.4, pp.502-523, 1990. ,
DOI : 10.1137/0403043
Polyhedral approaches to network survivability, Reliability of Computer and Communication Networks Series in Discrete Mathematics and Computer Science, pp.121-141, 1991. ,
Computational Results with a Cutting Plane Algorithm for Designing Communication Networks with Low-Connectivity Constraints, Operations Research, vol.40, issue.2, pp.309-330, 1992. ,
DOI : 10.1287/opre.40.2.309
Facets for Polyhedra Arising in the Design of Communication Networks with Low-Connectivity Constraints, SIAM Journal on Optimization, vol.2, issue.3, pp.474-504, 1992. ,
DOI : 10.1137/0802024
On container width and length in graphs, groups and networks, IEICE. Trans. Fundam E77, vol.4, pp.668-680, 1994. ,
Minimum-weight two-connected spanning networks, Mathematical Programming, pp.153-171, 1990. ,
DOI : 10.1007/BF01585735
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.83.5692
The Design of Minimum-Cost Survivable Networks, IEEE Transactions on Circuit Theory, vol.16, issue.4, pp.16455-460, 1969. ,
DOI : 10.1109/TCT.1969.1083004
Generalized Steiner problem in Halin graphs, Proceedings of the 12 th International Symposium on Mathematical Programming. MIT, 1985. ,
Generalized Steiner problem in series-parallel networks, Journal of Algorithms, vol.7, pp.549-566, 1986. ,
