Setting 2 variables at a time yields a new lower bound for random 3-sat, Proceeding of the 32nd ACM Symposium on Theory of Computing, pp.28-37, 2000. ,
Lower bounds for random 3-SAT via differential equations, Phase transitions in combinatorial problems, pp.159-185, 1999. ,
DOI : 10.1016/S0304-3975(01)00159-1
Optimal myopic algorithms for random 3-SAT, 41st Annual Symposium on Foundations of Computer Science, pp.590-600, 2000. ,
Length of prime implicants and number of solutions of random CNF formulae, Theoretical Computer Science, vol.215, issue.1-2, pp.1-30, 1999. ,
DOI : 10.1016/S0304-3975(95)00184-0
On the satisfiability and maximum satisfiability of random 3-CNF formulas, Proceedings of the Fourth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.322-330, 1993. ,
Probabilistic analysis of a generalization of the unit-clause literal selection heuristics for the k-satisfiability problem, Information Sciences. An International Journal, vol.51, issue.3, pp.289-314, 1990. ,
Upper bounds on the satisfiability threshold, Phase transitions in combinatorial problems, pp.187-197, 1999. ,
DOI : 10.1016/S0304-3975(01)00161-X
URL : https://hal.archives-ouvertes.fr/hal-01195615
A General Upper Bound for the Satisfiability Threshold of Randomr-SAT Formulae, Journal of Algorithms, vol.24, issue.2, pp.395-420, 1997. ,
DOI : 10.1006/jagm.1997.0867
Typical 3-sat formulae and the satisfiability threshold, Electronic Colloquium on computational complexity, 2003. ,
On Random 3-sat, Combinatorics, Probability and Computing, vol.4, issue.03, pp.189-195, 1995. ,
DOI : 10.1137/0215080
Results related to threshold phenomena research in satisfiability: lower bounds, Phase transitions in combinatorial problems, pp.147-157, 1999. ,
DOI : 10.1016/S0304-3975(01)00158-X
Probabilistic analysis of the Davis Putnam procedure for solving the satisfiability problem, Discrete Applied Mathematics, vol.5, issue.1, pp.77-87, 1983. ,
DOI : 10.1016/0166-218X(83)90017-3
Sharp thresholds of graph properties, and the k-sat problem, Journal of the American Mathematical Society, vol.12, issue.04, pp.1017-1054, 1999. ,
DOI : 10.1090/S0894-0347-99-00305-7
Analysis of Two Simple Heuristics on a Random Instance ofk-sat, Journal of Algorithms, vol.20, issue.2, pp.312-355, 1996. ,
DOI : 10.1006/jagm.1996.0016
Bounding the unsatisfiability threshold of random 3-SAT, MR 2001c:68065]. Random Structures and Algorithms, pp.103-11699, 2000. ,
DOI : 10.1002/1098-2418(200009)17:2<103::AID-RSA2>3.0.CO;2-P
Tail bounds for occupancy and the satisfiability threshold conjecture. Random Structures and Algorithms, pp.59-80, 1995. ,
The Probabilistic Analysis of a Greedy Satisfiability Algorithm, ESA 2002: 10th annual european symposium, pp.574-585, 2002. ,
DOI : 10.1007/3-540-45749-6_51
Approximating the unsatisfiability threshold of random formulas. Random Structures and Algorithms, pp.253-269, 1998. ,
´ Etude des transitions de phases en K-satisfaisabilité. Master's thesis, ´ Ecole polytechnique, 2000. ,
