On an open problem of Green and Losonczy: exact enumeration of freely braided permutations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2004
Toufik Mansour
Recently, Green and Losonczy~GL1,GL2 introduced \emphfreely braided permutation as a special class of restricted permutations has arisen in representation theory. The freely braided permutations were introduced and studied as the upper bound for the number of commutation classes of reduced expressions for an element of a simply laced Coxeter group is achieved if and only if when the element is freely braided. In this paper, we prove that the generating function for the number of freely braided permutations in S_n is given by \par (1-3x-2x^2+(1+x)√1-4x) / (1-4x-x^2+(1-x^2)√1-4x).\par
dm060218.pdf (72.6 Ko) Télécharger le fichier
hal-00959020 , version 1 (13-03-2014)
Toufik Mansour. On an open problem of Green and Losonczy: exact enumeration of freely braided permutations. Discrete Mathematics and Theoretical Computer Science, 2004, Vol. 6 no. 2 (2), pp.461-470. ⟨10.46298/dmtcs.327⟩. ⟨hal-00959020⟩
Collections
TDS-MACS
43 Consultations
652 Téléchargements
