Extremal Graph Theory, 1978. ,
DOI : 10.1201/b16132-57
On sequences of integers no one of which divides the product of two others and some related problems, Izv. Naustno-Issl, pp.74-82, 1938. ,
Graphs realizing the same degree sequences and their respective clique numbers, in Graph Theory, Combinatorics and Application, vol.1, pp.439-449, 1991. ,
Potentially G-graphic degree sequences, Combinatorics, Graph Theory and Algorithms, vol.2, pp.451-460, 1999. ,
A note on potentially K 4 ? e graphical sequences, Australasian J. of Combinatorics, vol.24, pp.123-127, 2001. ,
An extremal problem on the potentially P k -graphic sequences, Discrete Math, pp.223-231, 2000. ,
The smallest degree sum that yields potentially Pk???graphical sequences, Journal of Graph Theory, vol.29, issue.2, pp.63-72, 1998. ,
DOI : 10.1002/(SICI)1097-0118(199810)29:2<63::AID-JGT2>3.3.CO;2-1
On the potentially P k -graphic sequences, Discrete Math, pp.255-262, 1999. ,
The Erd? os-Jacobson-Lehel conjecture on potentially P k -graphic sequence is true, Science in China (Series A), pp.510-520, 1998. ,
On potentially C k -graphic sequences, Ars Combinatoria, vol.64, pp.301-318, 2002. ,
On an extremal problem in graph theory, pp.436-452, 1941. ,
An extremal problem on potentially K r,s -graphic sequences, Discrete Math, pp.295-305, 2003. ,
