Concise Oxford Dictionary, 2001. ,
A subdivision algorithm in configuration space for findpath with rotation, IEEE Transactions on Systems, Man, and Cybernetics, vol.15, issue.2, pp.224-233, 1985. ,
DOI : 10.1109/TSMC.1985.6313352
Robot motion planning using exact cell decomposition and potential field methods, Proceedings of the 9th WSEAS international conference on Simulation, modelling and optimization, ser. SMO'09, pp.126-131, 2009. ,
Computational Principles of Mobile Robotics, ser. Computational Principles of Mobile Robotics, 2010. ,
Dynamic visibility graph for path planning, 2004 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS) (IEEE Cat. No.04CH37566), pp.2813-2818, 2004. ,
DOI : 10.1109/IROS.2004.1389835
Planning shortest bounded-curvature paths for a class of nonholonomic vehicles among obstacles, Journal of Intelligent and Robotic Systems, vol.38, issue.5, pp.387-405, 1996. ,
DOI : 10.1007/BF00270450
A ???retraction??? method for planning the motion of a disc, Journal of Algorithms, vol.6, issue.1, pp.104-111, 1985. ,
DOI : 10.1016/0196-6774(85)90021-5
A note on two problems in connexion with graphs, Numerische Mathematik, vol.4, issue.1, pp.269-271, 1959. ,
DOI : 10.1007/BF01386390
A Formal Basis for the Heuristic Determination of Minimum Cost Paths, IEEE Transactions on Systems Science and Cybernetics, vol.4, issue.2, pp.100-107, 1968. ,
DOI : 10.1109/TSSC.1968.300136
Path planning of a mobile robot using genetic heuristics, Robotica, vol.16, issue.5, pp.575-588, 1998. ,
DOI : 10.1017/S0263574798000289
A mobile robot path planning using genetic algorithm in static environment, Journal of Computer Science, vol.4, issue.4, pp.341-344, 2008. ,
On the ???piano movers'??? problem I. The case of a two-dimensional rigid polygonal body moving amidst polygonal barriers, Communications on Pure and Applied Mathematics, vol.22, issue.3, pp.345-398, 1983. ,
DOI : 10.1002/cpa.3160360305
Principles of Artificial Intelligence, 1980. ,
DOI : 10.1007/978-3-662-09438-9
Optimal and Efficient Path Planning for Partially Known Environments, Robotics and Automation IEEE International Conference on, pp.3310-3317, 1994. ,
DOI : 10.1007/978-1-4615-6325-9_11
Topological simultaneous localization and mapping (SLAM): toward exact localization without explicit localization, IEEE Transactions on Robotics and Automation, vol.17, issue.2, pp.125-137, 2001. ,
DOI : 10.1109/70.928558
Mobile Robot Navigation: The CMU System, IEEE Expert, vol.2, issue.4, pp.44-54, 1987. ,
DOI : 10.1109/MEX.1987.5006533
Path-planning strategies for a point mobile automaton moving amidst unknown obstacles of arbitrary shape, ALGORITHMICA, 1987. ,
Real-time obstacle avoidance for manipulators and mobile robots, Robotics and Automation. Proceedings. 1985 IEEE International Conference on, pp.500-505, 1985. ,
Edition en anglais, ser. The Springer International Series in Engineering and Computer Science, 1991. ,
Potential field methods and their inherent limitations for mobile robot navigation, Proceedings. 1991 IEEE International Conference on Robotics and Automation, pp.1398-1404, 1991. ,
DOI : 10.1109/ROBOT.1991.131810
Developments in nonholonomic control problems, IEEE Control Systems Magazine, vol.15, issue.6, pp.20-36, 1995. ,
DOI : 10.1109/37.476384
Robot motion planning and control, ser. Lecture notes in control and information sciences, 1998. ,
Optimal trajectory generation for nonholonomic robots in dynamic environments, Robotics and Automation ICRA 2008. IEEE International Conference on, pp.2552-2557, 2008. ,
Performance-based reactive navigation for non-holonomic mobile robots, Robotica, vol.13, issue.02, pp.281-290, 2009. ,
DOI : 10.1016/S0005-1098(02)00012-2
Autonomous navigation of a nonholonomic mobile robot in a complex environment, 2008 IEEE International Workshop on Safety, Security and Rescue Robotics, pp.102-108, 2008. ,
DOI : 10.1109/SSRR.2008.4745885
A new range-sensor based globally convergent navigation algorithm for mobile robots, Proceedings of IEEE International Conference on Robotics and Automation, pp.429-435, 1996. ,
DOI : 10.1109/ROBOT.1996.503814
Flatness and defect of non-linear systems: introductory theory and examples, International Journal of Control, vol.4, issue.6, pp.1327-1361, 1995. ,
DOI : 10.1109/9.73561
Receding horizon control of nonlinear systems Automatic Control, IEEE Transactions on, vol.35, issue.7, pp.814-824, 1990. ,
User's guide for CFSQP version 2.5: AC code for solving (large scale) constrained nonlinear (minimax) optimization problems, generating iterates satisfying all inequality constraints, Institute for Systems Research TR, vol.94, pp.16-17 ,
A Computationally Efficient Feasible Sequential Quadratic Programming Algorithm, SIAM Journal on Optimization, vol.11, issue.4, pp.1092-1118, 2001. ,
DOI : 10.1137/S1052623498344562
An efficient algorith for determining the convex hull of a finite planar set, Information Processing Letters, vol.1, issue.4, pp.132-133, 1972. ,
DOI : 10.1016/0020-0190(72)90045-2
