Voronoi diagrams---a survey of a fundamental geometric data structure, ACM Computing Surveys, vol.23, issue.3, pp.345-405, 1991. ,
DOI : 10.1145/116873.116880
Voronoi diagrams, Handbook of Computational Geometry, pp.201-290, 2000. ,
Optimal Möbius transformations for information visualization and meshing, 7th Workshop on Algorithms and Data Structures, 2001. ,
DOI : 10.1007/3-540-44634-6_3
URL : http://arxiv.org/pdf/cs/0101006v1.pdf
Hyperbolic delaunay complexes and voronoi diagrams made practical, Proceedings of the 29th annual symposium on Symposuim on computational geometry, SoCG '13, pp.67-76, 2013. ,
DOI : 10.1145/2462356.2462365
URL : https://hal.archives-ouvertes.fr/hal-00961390
Covering spaces and Delaunay triangulations of the 2d flat torus, Abstracts 28th European Workshop on Computational Geometry, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01109626
Delaunay triangulations and cycles on closed hyperbolic surfaces, Research Report, vol.8434, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00921157
OUTPUT SENSITIVE CONSTRUCTION OF THE DELAUNAY TRIANGULATION OF POINTS LYING IN TWO PLANES, International Journal of Computational Geometry & Applications, vol.06, issue.01, pp.1-1410, 1996. ,
DOI : 10.1142/S0218195996000022
URL : https://hal.archives-ouvertes.fr/hal-00795075
Algorithmic Geometry, 1998. ,
DOI : 10.1017/CBO9781139172998
On the imbedding of systems of compacta in simplicial complexes, Fundamenta Mathematicae, vol.35, issue.1, pp.217-234, 1948. ,
Hyperbolic geometry. Flavors of geometry, pp.59-115, 1997. ,
Computing 3D Periodic Triangulations, 17th European Symposium on Algorithms, pp.37-48, 2009. ,
DOI : 10.1007/978-3-642-04128-0_6
URL : https://hal.archives-ouvertes.fr/inria-00356871
Delaunay triangulations of point sets in closed euclidean d-manifolds, Proceedings of the 27th annual ACM symposium on Computational geometry, SoCG '11, pp.274-28210, 2011. ,
DOI : 10.1145/1998196.1998236
URL : https://hal.archives-ouvertes.fr/hal-01101094
Computational Geometry Algorithms Library ,
An optimal convex hull algorithm in any fixed dimension, Discrete & Computational Geometry, vol.16, issue.4, pp.377-40910, 1993. ,
DOI : 10.1007/BF02573985
Bifurcation of Hyperbolic Planforms, Journal of Nonlinear Science, vol.10, issue.8, pp.465-49810, 2011. ,
DOI : 10.1007/s00332-010-9089-3
URL : https://hal.archives-ouvertes.fr/hal-00807355
Non-Euclidean Geometry, 1998. ,
Computational Geometry: Algorithms and Applications, 1997. ,
THE DELAUNAY HIERARCHY, International Journal of Foundations of Computer Science, vol.13, issue.02, pp.163-18010, 2002. ,
DOI : 10.1142/S0129054102001035
URL : https://hal.archives-ouvertes.fr/inria-00166711
The space of spheres, a geometric tool to unify duality results on Voronoi diagrams, Canad. Conf. Computational Geometry, pp.263-268, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-01180157
Efficient exact geometric predicates for Delaunay triangulations, In Workshop on Algorithm Engineering and Experimentation, pp.37-44, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00344517
WALKING IN A TRIANGULATION, International Journal of Foundations of Computer Science, vol.13, issue.02, pp.181-19910, 2002. ,
DOI : 10.1142/S0129054102001047
URL : https://hal.archives-ouvertes.fr/inria-00344519
Perturbations for Delaunay and weighted Delaunay 3D triangulations, Computational Geometry, vol.44, issue.3, pp.160-168, 2011. ,
DOI : 10.1016/j.comgeo.2010.09.010
URL : https://hal.archives-ouvertes.fr/inria-00560388
Voronoi diagrams and arrangements, Discrete & Computational Geometry, vol.24, issue.1, pp.25-4410, 1986. ,
DOI : 10.1007/BF02187681
Hyperbolic geometry, Möbius transformations, and geometric optimization Invited talk at MSRI Introductory Workshop on Discrete and Computational Geometry, 2003. ,
Succinct Greedy Graph Drawing in the Hyperbolic Plane, International Symposium on Graph Drawing, pp.14-25, 2008. ,
DOI : 10.1007/978-3-642-00219-9_3
The graphs of planar soap bubbles, Proceedings of the 29th annual symposium on Symposuim on computational geometry, SoCG '13, pp.27-36, 2013. ,
DOI : 10.1145/2462356.2462370
Generic programming and the CGAL library, Effective Comp. Geom. for Curves and Surfaces, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01053388
Number types, CGAL Manual. CGAL Ed. Board, 4.0 edition, 2012. ,
Cortical cartography using the discrete conformal approach of circle packings, NeuroImage, vol.23, pp.119-128, 2004. ,
DOI : 10.1016/j.neuroimage.2004.07.018
Discrete Surface Ricci Flow, IEEE Transactions on Visualization and Computer Graphics, vol.14, issue.5, pp.1030-1043, 2008. ,
DOI : 10.1109/TVCG.2008.57
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.392.3119
Generalization of Voronoi Diagrams in the Plane, SIAM Journal on Computing, vol.10, issue.1, pp.73-8710, 1981. ,
DOI : 10.1137/0210006
Exploring large graphs in 3D hyperbolic space, IEEE Computer Graphics and Applications, vol.18, issue.4, pp.18-23, 1998. ,
DOI : 10.1109/38.689657
Hyperbolic Voronoi Diagrams Made Easy, 2010 International Conference on Computational Science and Its Applications, pp.74-80, 2010. ,
DOI : 10.1109/ICCSA.2010.37
URL : http://arxiv.org/abs/0903.3287
Construction of Voronoi diagrams on the upper half-plane, IEICE Trans. Fundamentals, pp.79-533, 1996. ,
Hyperbolic centroidal Voronoi tessellation, In ACM Symp. on Solid and Physical Modeling, pp.117-126, 2010. ,
Meshing the hyperbolic octagon, Research Report, vol.8179 ,
URL : https://hal.archives-ouvertes.fr/hal-00764965
Revisiting Hyperbolic Voronoi Diagrams from Theoretical, Applied and Generalized Viewpoints, 2010 International Symposium on Voronoi Diagrams in Science and Engineering, pp.23-32, 2010. ,
DOI : 10.1109/ISVD.2010.13
Three dimensional manifolds, Kleinian groups and hyperbolic geometry, Bulletin of the American Mathematical Society, vol.6, issue.3, pp.357-381, 1982. ,
DOI : 10.1090/S0273-0979-1982-15003-0
The geometry and topology of three-manifolds, 2002. ,
Computing the n-dimensional Delaunay tessellation with application to Voronoi polytopes, The Computer Journal, vol.24, issue.2, pp.167-172, 1981. ,
DOI : 10.1093/comjnl/24.2.167
Curved Spaces, 2008. ,
THE EXACT COMPUTATION PARADIGM, Computing in Euclidean Geometry, pp.452-492, 1995. ,
DOI : 10.1142/9789812831699_0011
2D triangulations, CGAL Manual. CGAL Ed. Board, p.2, 2012. ,
Resilient Routing for Sensor Networks Using Hyperbolic Embedding of Universal Covering Space, 2010 Proceedings IEEE INFOCOM, pp.1694-1702, 2010. ,
DOI : 10.1109/INFCOM.2010.5461988
