Query-Based Why-Not Provenance with NedExplain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With the increasing amount of available data and transformations manipulating the data, it has become essential to analyze and debug data transformations. A sub-problem of data transformation analysis is to understand why some data are not part of the result of a relational query. One possibility to explain the lack of data in a query result is to identify where in the query we lost data pertinent to the expected outcome. A first approach to this so called why-not provenance has been recently proposed, but we show that this first approach has some shortcomings. To overcome these shortcomings, we propose \ned, an algorithm to explain data missing from a query result. NedExplain computes the why-not provenance for monotone relational queries with aggregation. After providing necessary definitions, this paper contributes a detailed description of the algorithm. A comparative evaluation shows that it is both more efficient and effective than the state-of-the-art approach.
ned_edbt2014.pdf (613.97 Ko) Télécharger le fichier
hal-00962157 , version 1 (20-03-2014)
  • HAL Id : hal-00962157 , version 1
Nicole Bidoit, Melanie Herschel, Katerina Tzompanaki. Query-Based Why-Not Provenance with NedExplain. Extending Database Technology (EDBT), Mar 2014, Athens, Greece. ⟨hal-00962157⟩
451 Consultations
509 Téléchargements
